[mapserver-users] Slow Response or Timeout for Mapserver 6.4 on Linux
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jun 29 05:58:08 PDT 2016
Hello,
I would check your Apache access logs for the full requests, and compare
them for the different clients (OpenLayers, QGIS, etc.), you might even
paste 2 of these full GetMap urls here for the mailing list to compare
the parameters - maybe one client is using something different causing
your issue (?)
I had been facing a lot of truncated GetCapabilities requests in the
MapServer 6 series, but have not seen any issues with MapServer 7.
(there were lots of tickets for that old issue, but here is one example:
https://github.com/mapserver/mapserver/issues/4505)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-06-29 9:16 AM, Berger, Cora wrote:
> Hello all,
> I was working with Mapserver on Windows before. Now we moved to Linux. We use Mapserver 6.4.1.
> The response time to GetCapabilities and GetMap - requests for the same WMS vary a lot, depending on if you send the requests via browser or an Open Layers application or some other viewers or GIS. Often the requests even run on a timeout. The server is not busy at all.
> Does anybody know why?
> I saw your message from 2014 Jukka Rahkonen concerning " Slow output to PNG format with Mapserver 6.4" but you didn't seem to get a response.
> Any clues?
