[mapserver-users] Get current year in a CLASS EXPRESSION (mapfile)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Mar 23 07:50:18 PDT 2016
You can read about the postgres "to_char" function that I used (to go
from date to a string) here:
http://www.postgresql.org/docs/9.5/static/functions-formatting.html
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-03-23 11:45 AM, Jeff McKenna wrote:
> Hello Thomas (when you ask for help it's good karma to include your name),
> If I was in this situation, here would be my steps:
> 1. Focus first on Postgres, and see if I can get the first 4 characters
> of a date column, through the commandline tool "psql". For example, see
> the "substring" function at
> http://www.postgresql.org/docs/9.5/static/functions-string.html
> Here is a psql command that works for me with Postgres 9.5, where I am
> querying a date column "pubdate", using the first 4 characters, and
> trying to return the instances where those characters are '2013':
> # select id, geom, substring(to_char(pubdate, 'YYYY-MM-DD') from 1 for
> 4) from "mytable" where substring(to_char(pubdate, 'YYYY-MM-DD') from 1
> for 4) = '2013';
> 2. Once that is working, I would move onto test through OGR, directly to
> this Postgres instance, with the commandline utility "ogrinfo".
> Here is my first command to connect:
> ogrinfo -ro PG:"host=localhost user=postgres password=postgres
> dbname=mydbname_csu port=5438" mytable -summary
> Next I want to try that same psql select command through ogrinfo, which
> has a "-sql" switch to test queries:
> dbname=mydbname port=5438" mytable -sql "select geom,
> substring(to_char(pubdate, 'YYYY-MM-DD') from 1 for 4) from mytable
> where substring(to_char(pubdate, 'YYYY-MM-DD') from 1 for 4) = '2013'
> That should return the correct features.
> 3. Once that is working, then I would use that in my mapfile layer, and
> try labeling features just with those 4 date characters, such as:
> LAYER
> NAME "test"
> STATUS ON
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "PG:host=localhost user=postgres password=postgres
> DATA "select geom, id, substring(to_char(pubdate, 'YYYY-MM-DD')
> from 1 for 4) as pubtext from mytable"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> LABELITEM "pubtext"
> CLASS
> NAME "test"
> STYLE
> COLOR 235 234 85
> END # STYLE
> LABEL
> COLOR 255 0 0
> FONT sans-italic
> TYPE truetype
> SIZE 8
> POSITION AUTO
> PARTIALS FALSE
> OUTLINECOLOR 255 255 255
> END # LABEL
> END # CLASS
> END # LAYER
> The above was tested with MS4W 3.1.3 (MapServer 7.0.1) and PostgreSQL 9.5
> -jeff
