[mapserver-users] Oracle SYSDATE in EXPRESSION
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Mar 29 09:20:51 PDT 2016
Dan,
That would work, but I was trying to color a 5 year old class one color, and the rest of them another, and do it all in one SQL call (single layer)
I got it to work in the DATA connection, but was trying to do the STYLE based query in the CLASS block.
Seems like it would be doable, but I’m not having any luck yet. I’m guessing that the SYSDATE is not getting passed in correctly along with the INDATE value, at least based on what I see when I intentionally break the SQL to see the error.
Also, there are only 1700 records to work with in there right now, quick return no matter what.
bobb
On Mar 29, 2016, at 11:10 AM, Dan Little <theduckylittle at gmail.com<mailto:theduckylittle at gmail.com>> wrote:
You're probably better off with a view or querying against a stored procedure. There are a few advantages:
1. With a view you can create multiple arbitrary views.
2. It keeps the syntax of the mapfile cleaner.
3. A view is easy to change to a materialized view in Oracle. That has a pile of performance benefits.
4. A stored procedure can be used to normalize the data better between Oracle and mapserver.
On Tue, Mar 29, 2016 at 10:53 AM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>> wrote:
All Oracle Guru’s,
How do I handle an expression for doing a timed query in Oracle:
CLASS
EXPRESSION ('[indate] > SYSDATE - 1825')
COLOR 255 255 254
OUTLINECOLOR 0 0 0
SIZE 10
SYMBOL 'circle'
NAME "PW Sidewalk Permits"
END
I want to get all the Permits up to 5 years old to plot. What should the EXPRESSION line look like above. I’ve tried all sort of different combinations of quoting, etc. I either get everything, or nothing.
Thanks
bobb
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160329/405d6bd8/attachment-0001.html>
