[mapserver-users] WFS - featureid/resourceid
TC Haddad tchaddad at gmail.com
Sat May 7 12:56:34 PDT 2016
No - it seems the result could return successfully in either format, so the
server config is fine.
What is the data storage format? perhaps that is the driver that is
reporting the error...
On Sat, May 7, 2016 at 12:53 PM, Ian Walberg <ian.walberg at airborne.aero>
wrote:
> That did not seem to make any difference, can you tell from here what
> output types should work?
> http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetCapabilities
> Thanks
> Ian
> *From:* TC Haddad [mailto:tchaddad at gmail.com <tchaddad at gmail.com>]
> *Sent:* Saturday, May 7, 2016 12:46 PM
> *To:* Ian Walberg <ian.walberg at airborne.aero>
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] WFS - featureid/resourceid
> Try adding GML as a format option to see if you are able to get a result
> that way:
> "wfs_getfeature_formatlist" "gml,geojson"
> On Sat, May 7, 2016 at 12:43 PM, Ian Walberg <ian.walberg at airborne.aero>
> wrote:
> Yes we see the same and that was my reason for asking.
> Thanks
> Ian
> *From:* TC Haddad [mailto:tchaddad at gmail.com]
> *Sent:* Saturday, May 7, 2016 12:39 PM
> Well it looks like your map file settings are fine, and a correctly
> formatted URL would be:
> http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&STOREDQUERY_ID=urn:ogc:def:query:OGC-WFS::GetFeatureById&ID=DATA_TEST.1
> However the resulting error message indicates that something may else may
> be amiss:
> msQueryByFilter(): Search returned no results. No matching record(s) found.
> LayerDefaultTranslateFilter(): General error message. This data driver
> does not implement filter translation support
> On Sat, May 7, 2016 at 12:29 PM, Ian Walberg <ian.walberg at airborne.aero>
> wrote:
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160507/bd7b8938/attachment.html>
