[mapserver-users] runtime CONNECTION string partial substitution
thomas bonfort thomas.bonfort at gmail.com
Mon May 16 05:10:58 PDT 2016
On May 16, 2016 2:02 PM, "Rahkonen Jukka (MML)" <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Correction:
> Changing the WMS online resource does work if the mapfile is written
correctly. I had to add VALIDATION also into MAP->WEB
> WEB
>     METADATA
> "wms_onlineresource" "http://localhost:8060/cgi-bin/mapserv.exe?map=c
:\ms4w\apps\wms-wfs.map&db=%db%"
>     END #metadata
>      VALIDATION
>              "db" "[a-z]+"
>     END #validation
> END #WEB
> Now I can send
http://localhost:8060/cgi-bin/mapserv.exe?map=c:/ms4w/apps/wms-wfs.map&service=wms&version=1.3.0&request=getcapabilities&db=wms-wfs
> and get
> <OnlineResource xlink:href="
:\ms4w\apps\wms-wfs.map&db=wms-wfs&"/>
> What is interesting is that the validation rule “[a-z]+” should not
accept the name of my db “wms-wfs” but it does. Capital letters are
accepted as well “WMS-WFS”. Because I am on Windows I can even get data
with WMS-WFS though the name of the db is “wms-wfs.sqlite”.
That's because [a-z]+ means "there should be at least one alphabetic
character in the passed expression". The " correct" regex to use would be
^[a-z]+$
Thomas
> -Jukka Rahkonen-
> Lähettäjä: Rahkonen Jukka (MML)
> Lähetetty: 16. toukokuuta 2016 14:24
> Vastaanottaja: 'G. Allegri'; mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] runtime CONNECTION string partial substitution
> Hi,
> I made a test with your VALIDATION and CONNECTION and changing  db
on-the-fly works. How did you test?  If you use some WMS client for testing
it is good to remember that variable substitution does not have an effect
on the GetCapabilities document so that the GetMap URL would be updated
automatically. Therefore WMS clients like QGIS or OpenJUMP will drop the
&db= parameter from the GetMaps if you do not tell them not to trust the
advertised GetMap URL.
> According to documentation http://mapserver.org/cgi/runsub.html  it
should also be possible to use variable substitution also in MAP- WEB:
METADATA. I tried
> to use
> "wms_onlineresource" “http://localhost:8060/cgi-bin/mapserv.exe?map=c
:\ms4w\apps\wms-wfs.map&%db%”
> but GetCapabilities response contains the variable %db% literally
:\ms4w\apps\wms-wfs.map&%db%&"/>
> It seems that for getting a proper error message when &db= is missing or
it is wrong a WMS GetMap request is required. WFS GetFeature triggers the
error
> and is easier to write by hand, for example:
http://localhost:8060/cgi-bin/mapserv.exe?map=c:/ms4w/apps/wms-wfs.map&service=wfs&version=2.0.0&request=getfeature&typename=states&db=foo
> sends an error
> <ows:ExceptionText>
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
`states'.  File not found or unsupported format.
> </ows:ExceptionText>
> Document http://www.mapserver.org/optimization/debugging.html contains
good advice for debugging.
> -Jukka Rahkonen-
> G. Allegri wrote:
> Hello,
> I'm trying to define a layer where the Sqlite DB connection should be set
dynamically through runtime sustitution.
> e.g.
> LAYER
>     NAME mylayer
>     TYPE POINT
>     CONNECTIONTYPE OGR
>     VALIDATION
>         "db" "[a-z]+"
>     END
>     CONNECTION "/var/www/dbs/%db%.sqlite"
>     DATA "mytable"
> END
> The point layers works fine if  %db% is set statically but if I try to
define it through get query values nothing is returned:
> http://localhost/cgi-bin/mapserv?map=mymapfile.map&db=mydb
> The documentation says that runtime sustitution should work for
CONNECTION param too. What am I doing wrong?
> Thanks,
> Giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> Gis3W - http://gis3w.it
> Ikare - http://ikare.it
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160516/79f38664/attachment.html>
