[mapserver-users] Testing x64 MapServer
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed May 18 11:36:24 PDT 2016
If I had to guess, it would be that you are not properly pointing to the
full path to the MSSQL plugin: for example, see
http://ms4w.com/README_INSTALL.html#microsoft-sql-server-2008
I am happy to hear that MS4W is doing so well for sharing your
organization's spatial needs.  Please feel free to help fund MS4W, to
make sure that the MS4W product remains so innovative and reliable for
your organization in the long term.  You can contact me directly at any
time to offer that help. Thank you,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-05-18 3:17 PM, Vogt, Robert   (RCIS) wrote:
> Good afternoon I’m trying to set up x64 MapServer on Windows 2012 server.
> I’ve been partially successful in that the MapServer dll’s are all there
> but when I run my .map file through shp2img.exe
> The process is failing on a .map file that worked previously.
> This is what the map file looks like …
> MAP
>   NAME USA1
>   SYMBOLSET "e:\arcgisserver\basedata\symbols.txt"
>   FONTSET "e:\arcgisserver\basedata\fonts.txt"
>   STATUS ON
>   IMAGETYPE PNG8
>   RESOLUTION 72
>   IMAGECOLOR 255 255 255
>   SHAPEPATH "e:\arcgisserver\basedata"
>   UNITS METERS
>   PROJECTION "proj=lcc" "lat_1=20" "lat_2=60" "lat_0=40"
> "lon_0=-112.52116185" "x_0=0" "y_0=0" "ellps=GRS80" "units=m"
> "datum=NAD83" END
>   SIZE 1500 1500
>   EXTENT -45292.7219576058 780481.616003812 45290.5126012127 871065.05991903
>   LAYER
>     STATUS DEFAULT
>     CONNECTIONTYPE PLUGIN CONNECTION "server=Left Blank on purpose, I’ve
> tested the connection with a .udl file on the server"
>     PLUGIN "msplugin_mssql2008.dll"
>     DATA "shape(geography) from FARMMAPS.GIS.STATE USING INDEX S7_idx
> USING UNIQUE OBJECTID USING SRID=4269"
>     NAME "States"
>     TYPE POLYGON
>     STATUS DEFAULT
>     PROJECTION "proj=longlat" "ellps=GRS80" "datum=NAD83" "no_defs" END
>     LABELITEM "state"
>     CLASS
>       NAME "States"
>       STYLE
>         SYMBOL 0
>         WIDTH 2 OUTLINECOLOR 255 0 0
>       END
>       LABEL TYPE truetype
>         FONT arial
>         PRIORITY 2
>         ALIGN center
>         SIZE 10
>         COLOR 255 0 0
>         OUTLINECOLOR 255 255 255
>         OUTLINEWIDTH 2
>         MINDISTANCE 300
>         ANGLE AUTO
>         WRAP "~"
>       END
>     END
>   END
> END
> I have tested the SQL connection string with a .udl file on the server
> and it is working.
> The out put of shp2img.exe looks like this…
> PS E:\rcis\web\MapServerDlls> ./shp2img.exe -m
> E:\RCIS\Web\MapServerDlls\MapServerTest\map4.map -o E:\RCIS\Web\MapServer
> Dlls\MapServerTest\image1.png -all_debug 5
> msLoadMap(): 0.000s
> msDrawMap(): rendering using outputformat named png8 (AGG/PNG8).
> msDrawMap(): WMS/WFS set-up and query, 0.000s
> msDrawMap(): Image handling error. Failed to draw layer named 'States'.
> msDrawMap(): Image handling error. Failed to draw layer named 'States'. <br>
> msFreeMap(): freeing map at 00000067B88C2DE0.
