[mapserver-users] arcgis 10.3 enterprise geodatabase
Fawcett, David (MNIT) David.Fawcett at state.mn.us
Mon Nov 7 06:10:03 PST 2016
When you create your ‘feature class’ / table in the database using ESRI tools, you use the config option PG_GEOMETRY.  This uses PostGIS’s geometry type instead of ESRI’s.
With this setup, you can read and edit the data with ESRI products, and you can also access the features with straight PostGIS queries.  You can then just create a Mapserver layer with connectiontype of POSTGIS and point it at your database table.  http://www.mapserver.org/input/vector/postgis.html
Sent: Friday, November 04, 2016 8:18 AM
To: Fawcett, David (MNIT) <David.Fawcett at state.mn.us>
Cc: Michael Smith <michael.smith.erdc at gmail.com>; Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>; mapserver-users at lists.osgeo.org; Wingfield, Nathaniel D <nw at dcp.ufl.edu>
Subject: RE: [mapserver-users] arcgis 10.3 enterprise geodatabase
How can I Store enterprice data as pg_geometry and manage versión a in Mapserver?
El nov 3, 2016 2:10 PM, "Fawcett, David (MNIT)" <David.Fawcett at state.mn.us<mailto:David.Fawcett at state.mn.us>> escribió:
We do the same thing, but on PostGIS with pg_geometry.
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Michael Smith
Sent: Thursday, November 03, 2016 3:08 PM
To: Lime, Steve D (MNIT) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>; Oscar ^_^ <oscarfbh at gmail.com<mailto:oscarfbh at gmail.com>>; Wingfield, Nathaniel D <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] arcgis 10.3 enterprise geodatabase
The other option, which is what we use, is to store ArcGIS 10.3 enterprise data as SDO_GEOMETRY native. We find no performance penalties in ArcGIS and performance benefits for non-esri software, such as mapserver.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: mapserver-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> on behalf of "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>
Date: Thursday, November 3, 2016 at 4:02 PM
To: Oscar ^_^ <oscarfbh at gmail.com<mailto:oscarfbh at gmail.com>>, "Wingfield, Nathaniel D" <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>
Cc: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
If GDAL/OGR can handle the format then you’re in luck. I’d check there first…
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Oscar ^_^
Sent: Thursday, November 03, 2016 2:51 PM
To: Wingfield, Nathaniel D <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>
I've got the same requeriment althought i can use 10.1 or 10.2 but i don't know how to implement these to Mapserver....
Any suggestion o guide ??
2016-11-01 7:39 GMT-06:00 Wingfield, Nathaniel D <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>:
Can MapServer consume spatial data from an ArcGIS 10.3 enterprise geodatabase? We are using the default SDE.ST_GEOMETRY type, on Oracle. The MapServer docs indicate that any support for ESRI enterprise geodatabases is based on ArcSDE, which was abandoned by ESRI at version 10.3, in favor of direct connect (https://blogs.esri.com/esri/supportcenter/2015/02/11/where-is-the-install-for-arcsde-10-3/).
We will likely use OpenLayers for a new web-based mapping app, so MapServer seems like a natural choice (otherwise we will have to use ArcGIS Server).
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
OSCAR
^_^
 Y
_______________________________________________ mapserver-users mailing list mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161107/29700c07/attachment-0001.html>
