[mapserver-users] Symbols for railroad rendering in svg
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Nov 21 04:41:14 PST 2016
MapServer does have a "Symbology Exchange" section on the wiki; it would
be great to share your great symbol examples there:
https://github.com/mapserver/mapserver/wiki/MapServer-Symbology-Exchange
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-11-21 8:35 AM, TMa Teng wrote:
> Thanks Andy,
> My 'tie' symbol is same as your 'railway', the actual problem is the track...
> My original one is as follow:
> SYMBOL
> NAME "line_solid"
> TYPE ellipse
> POINTS 1 1
> END
> FILLED true
> END
> I changed it to what you suggested, and it works perfectly for SVG output.
> Really appreciate your help.
> Best regards,
> Teng
> -----Original Message-----
> From: Andy Colson [mailto:andy at squeakycode.net]
> Sent: Friday, November 18, 2016 8:53 PM
> To: TMa Teng <TMa at edrnet.com>; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Symbols for railroad rendering in svg
> Oh, also, my mapserver is:
> MapServer version 7.0.2 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> On 11/18/2016 05:36 PM, TMa Teng wrote:
>> Thanks for sharing your method.
>> However that is still brush line for the railway symbol which is not supported when using SVG format, isn’t it? Could you verify if a wms getmap call which contains the railway layer and in the getmap request set the output format=SVG to see if that works at your side?
>> Thanks again,
>> Teng
>> Sent: Friday, November 18, 2016 5:52 PM
>> To: mapserver-users at lists.osgeo.org; TMa Teng <TMa at edrnet.com>
>> On 11/18/2016 2:22 PM, TMa Teng wrote:
>>> Hi all,
>>> I am working on a project to export the wms to SVG format, it is the from the requirement of the features to be in vector format. And I am facing trouble to use the render engine to render the railroad symbol as a brush line.
>>> RailRoad Symbol I am using is as follow:
>>> CLASS
>>> NAME "MD_Railroad"
>>> STYLE
>>> SYMBOL "line_solid"
>>> SIZE 2
>>> COLOR 0 0 0
>>> END
>>> STYLE
>>> SYMBOL "tie"
>>> SIZE 6
>>> COLOR 0 0 0
>>> GAP -10
>>> END
>>> END
>>> It works as expect when the return image in raster format such as PNG, but when using SVG it shows error:
>>> "msDrawLineSymbol(): Renderer error. renderer does not support brushed lines"
>>> Does anyone have any suggestion about how to design a vector-enabled symbol for railways please? I am using MapServer 7.0, data is in SQL Server Spatial.
>>> Best regards,
>>> Teng
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Without seeing the "tie" symbol, its hard to say if mine is different.
>> Here's how I draw mine:
>> SYMBOL
>> NAME "railway"
>> TYPE truetype
>> FONT "Vera"
>> CHARACTER "|"
>> END
>> CLASS
>> NAME 'Railroad'
>> STYLE
>> SYMBOL 0
>> COLOR 0 0 0
>> SIZE 1
>> END
>> STYLE
>> SYMBOL 'railway'
>> COLOR 0 0 0
>> SIZE 7
>> GAP -10
>> END
>> END
>> -Andy
