[mapserver-users] Label frame offset with leader line
thomas bonfort
thomas.bonfort at gmail.com
Thu Sep 15 07:36:58 PDT 2016
It's a bug, you can open an issue for it.
thomas
On 15 September 2016 at 16:19, Stephen O'Connell
<stephen.oconnell at navigraph.com> wrote:
> Hello.
> I have a problem with label rendering Mapserver, and I haven't been able to
> find a solution myself.
> I'm rendering point labels with GEOMTRANSFORM 'labelpoly' to get a frame
> around the label. To get more labels to show, I have enabled LEADER so that
> labels are more likely to be visible but farther away from the point.
> However, when a label is moved away and attached with a LEADER, then the
> frame around the label gets an offset both vertically and horizontally. See
> the image https://www.dropbox.com/s/hwbt370d8371oqw/labeloffset.png?dl=0
> where the bottom left label has a leader, but the green frame is moved a few
> pixels down and to the right.
> Is the combination of LEADER and GEOMTRANSFORM 'labelpoly' not supported, or
> am I doing something wrong?
> Here is a section of my mapfile for the relevant layer:
> LABEL
> WRAP "!"
> ALIGN center
> TEXT ('[name]' + "!D116.7 " + '[ident]')
> MAXSCALEDENOM 2600064
> POSITION auto
> PARTIALS false
> SIZE 8
> COLOR 100 150 100
> TYPE truetype
> FONT vera
> FORCE false
> STYLE
> OFFSET 2 2
> COLOR 150 200 150
> OUTLINECOLOR 150 200 150
> WIDTH 1
> OPACITY 100
> END
> STYLE
> COLOR 255 255 255
> WIDTH 1
> OPACITY 95
> END
> END
> LEADER
> GRIDSTEP 40
> MAXDISTANCE 1000
> STYLE
> COLOR 150 200 150
> WIDTH 2
> END
> END
> I appreciate any assistance or comments.
> Kind regards,
> Stephen
> mapserver-users at lists.osgeo.org
