[mapserver-users] CONGIG MS_ERRORFILE ownership
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Apr 13 11:27:26 PDT 2017
On 4/13/2017 1:26 PM, Stefanos Anastasiou wrote:
> Hello list,
> I noticed that when I set the CONFIG "MS_ERRORFILE"
> "/home/stefanos/mapdata/log_file.log" it is saved with ownership to
> www-data for both user and group. Well this seems to cause problem for
> Python mapscript (at least at my machine with Python version 2.7 -
> Python 3 is not able to import mapscript at all). I'm using Spyder as
> an environment and it gives me the following message
> MapServerError: msSetErrorFile(): General error message. Failed to open
> MS_ERRORFILE /home/stefanos/mapdata/log_file.log
> mapserv -v
> MapServer version 7.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV
> SUPPORTS=XMP SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Is there any way to solve this issue ?
Create the file before you use and make if group writable and group
owned by www-data
sudo rm /home/stefanos/mapdata/log_file.log
touch /home/stefanos/mapdata/log_file.log
chmod 664 /home/stefanos/mapdata/log_file.log
sudo chgrp www-data /home/stefanos/mapdata/log_file.log
-Steve W
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
