[mapserver-users] geotiff 48bit with mapserver 7 wms
David
david at impstyle.com
Mon Apr 17 15:14:28 PDT 2017
Thank you very much Steve. You helped me to understand the problem!
David F.
------ Original Message ------
From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
To: mapserver-users at lists.osgeo.org
Sent: 4/14/2017 9:54:20 PM
Subject: Re: [mapserver-users] geotiff 48bit with mapserver 7 wms
>Yeah, technically a geotiff can be any format, but mapserver only
>supports a limit set for band widths.
>A new version of Mapcache was just released and it has GDAL support in
>it and serves WMS, but I'm not sure if it will do what you want.
>Sorry, I'm out of ideas on this.
>-Steve W
>On 4/14/2017 6:56 PM, David F. wrote:
>>I did not reply after my latest test, sorry.
>>I tried all tiff IMAGEMODE for my data set. None gave me 16 bit at the
>>gis client.
>>As far as I understand gtiff is 8 bit.
>>The only IMAGEMODE for integer is signed INT16 , which is
>>unfortunately the only supported integer data type. For RGB data
>>unsigned integer is the only integer data type that makes sense. Just
>>if i change the IMAGEMODE to FLOAT32 mapserver will serve more than 8
>>bit per band.
>>I think i will give gdal and float32 bit a try nevertheless it will
>>double the image size.
>>Maybe someone else has an idea.
>>On April 14, 2017 1:43:09 PM Stephen Woodbridge
>><woodbri at swoodbridge.com> wrote:
>>>http://mapserver.org/mapfile/outputformat.html
>>>Why not serve them a GTiff format for qgis?
>>>You can define multiple output formats in the mapfile, and let the
>>>browser use the 8bit png and have qgis request images in gtiff
>>>format.
>>>-Steve
>>>On 4/13/2017 11:03 AM, David wrote:
>>>>Hi Steve,
>>>>thank you very much for your help. The Mapserver is serving the
>>>>tiles
>>>>with the correct RGB values now. The problem is, that it is serving
>>>>8
>>>>bit per band and not 16 bit.
>>>>I need the 16bit because i want to use the wms as a base layer for
>>>>some
>>>>further processing with qgis or another gis client. So no problem
>>>>regarding browsers for me.
>>>>I will take a look and change the data type to float32 for the tiff
>>>>files. At least this is an supported OUTPUTFORMAT for mapserver.
>>>>Any suggestions on this matter are highly appreciated.
>>>>Cheers,
>>>>David
>>>>From: mapserver-users-request at lists.osgeo.org
>>>>Sent: 4/12/2017 4:00:02 PM
>>>>Subject: mapserver-users Digest, Vol 111, Issue 5
>>>>>Send mapserver-users mailing list submissions to
>>>>>To subscribe or unsubscribe via the World Wide Web, visit
>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>or, via email, send a message with subject or body 'help' to
>>>>>You can reach the person managing the list at
>>>>> mapserver-users-owner at lists.osgeo.org
>>>>>When replying, please edit your Subject line so it is more specific
>>>>>than "Re: Contents of mapserver-users digest..."
>>>>>Today's Topics:
>>>>> 1. geotiff 48bit with mapserver 7 wms (David)
>>>>> 2. Re: geotiff 48bit with mapserver 7 wms (Stephen Woodbridge)
>>>>>Message: 1
>>>>>Date: Wed, 12 Apr 2017 00:22:12 +0000
>>>>>From: David <david at impstyle.com>
>>>>>Subject: [mapserver-users] geotiff 48bit with mapserver 7 wms
>>>>>Message-ID:
>>>>><em5ce0e1b3-00b1-463e-8ad8-90100518d131 at laptop-dfriedrich>
>>>>>Content-Type: text/plain; charset="utf-8"; Format="flowed"
>>>>>Hi there,
>>>>>iam having some trouble to serve 48 bit geotiff images with a
>>>>>mapserver
>>>>>7 wms. I created to layers for speed purposes with scale limiters.
>>>>>The
>>>>>lowres layer is served well and looks good, it is 24bit geotiff
>>>>>data(8bit per channel). But if the layer changes to the highres,
>>>>>48bit
>>>>>geotiff data(16bit per channel), the data is shown wrong.
>>>>>I searched for some hints regarding a similar issue but could not
>>>>>find
>>>>>something.
>>>>>This is a screenshot of the loaded highres layer. It does not
>>>>>matter if
>>>>>i load a bbox inside the browser, qgis or another wms client. The
>>>>>highres data looks always the same.
>>>>>image loaded from highres layer:
>>>>>http://imgur.com/a/B65cp
>>>>>the mapfile:
>>>>>https://pastebin.com/4G2DZErZ
>>>>>the gdalinfo for one 16bit 3-band tile:
>>>>>https://pastebin.com/kfS0BjmE
>>>>>Best Regards,
>>>>>David
>>>>>-------------- next part --------------
>>>>>An HTML attachment was scrubbed...
>>>>>URL:
>>>>><http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170412/2cded6b6/attachment-0001.html>
>>>>>Message: 2
>>>>>Date: Tue, 11 Apr 2017 21:25:01 -0400
>>>>>From: Stephen Woodbridge <woodbri at swoodbridge.com>
>>>>>Message-ID: <a7bc734d-f7b9-32f3-5ce0-6a71aab4ead4 at swoodbridge.com>
>>>>>Content-Type: text/plain; charset=utf-8; format=flowed
>>>>>Read this:
>>>>>http://mapserver.org/input/raster.html
>>>>>You need to add to your highres layer
>>>>>PROCESSING "SCALE=AUTO"
>>>>>Or per band scaling. I done thing most browsers know what to do
>>>>>with 16
>>>>>bits per channel.
>>>>>-Steve W
>>>>>On 4/11/2017 8:22 PM, David wrote:
>>>>>> Hi there,
>>>>>>mapserver
>>>>>>limiters. The
>>>>>>48bit
>>>>>>find
>>>>>> something.
>>>>>>matter if
>>>>>> the mapfile:
>>>>>> Best Regards,
>>>>>> David
>>>>>> _______________________________________________
>>>>>This email has been checked for viruses by Avast antivirus
>>>>>software.
>>>>>https://www.avast.com/antivirus
>>>>>Subject: Digest Footer
>>>>>End of mapserver-users Digest, Vol 111, Issue 5
>>>This email has been checked for viruses by Avast antivirus software.
