[mapserver-users] Wrong about cgi feature parameter
Ahmet Temiz ahmettemiz88 at gmail.com
Tue Aug 1 01:49:39 PDT 2017
Thank you Steve for your detailed help.
Actually I intended to create polygon using OpenLayers, then sending
coordinates
to mapserver as feature object. I am going to use this polygon feature as a
mask
to crop related portion of raster map.
It was OK for simple rectangle polygon. Now, I am looking for a way for
complex polygon which has so many points.
Do you have any idea about whether I can assign a GeoJSON object for a
feature in URL request ?
Regards
On Mon, Jul 31, 2017 at 10:41 PM, Lime, Steve D (MNIT) <
steve.lime at state.mn.us> wrote:
> I was able to get something very similar working, albeit via a straight
> MapServer CGI call – didn’t try WMS. I noticed in your example you
> reference two layers poor and polf, is that intended?
> Request:
>   http://maps1.dnr.state.mn.us/cgi-bin/mapserv72?map=/usr/
> local/mapserver/apps/test/temiz/test.map&mode=map&layer=
> polf&map_layer[polf]=FEATURE+POINTS+3559569+5042506+END+END
> Mapfile:
> MAP
>   NAME 'ahmet temiz test mapfile'
>   EXTENT 2857613.741389 4274927.875099 4989229.633477 5176940.449967
>   SIZE 400 300
>   SYMBOL
>     NAME 'circle'
>     TYPE ELLIPSE
>     POINTS 1 1 END
>     FILLED TRUE
>   END
>   LAYER
>     NAME 'polf'
>     TYPE POINT
>     STATUS OFF
>     CLASS
>       STYLE COLOR 255 0 0 SYMBOL 'circle' SIZE 10 END
>     END
>   END
> END
> --Steve
> *From:* mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] *On
> Behalf Of *Ahmet Temiz
> *Sent:* Friday, July 28, 2017 11:12 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Wrong about cgi feature parameter
> Hi,
> I want to create a feature dynamically for point layer.
> But,What am I doing wrong ? It must be about feature parameter. But I was
> not able to solve it.
> This request generates nothing.
> curl --trace -i -g -X GET -H "Content-Type: image/png" "
> http://localhost/cgi-bin/mapserv?map=/var/www/ms_map/
> slptrRGB3857.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&Layers=poor
> END&STYLES=&SRS=EPSG:3857&BBOX=2857613.741389,4274927.
> 875099,4989229.633477,5176940.449967&WIDTH=400&HEIGHT=300&FORMAT=image/png"
> If you can help, I will appreciate.
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Bilgi İşlem  Dairesi Başkanlığı-CBS Grubu
> ________________________
> Ahmet Temiz
> Geological Eng.
> Information Systems - GIS Group
> Disaster and Emergency Management
> of Presidency
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170801/2ef1510f/attachment-0001.html>
