[mapserver-users] Segfault - LINE layer
Dave Barter dave at phased.co.uk
Fri Aug 18 06:04:51 PDT 2017
> On 18 Aug 2017, at 13:44, Lime, Steve D (MNIT) <steve.lime at state.mn.us> wrote:
> I'd call it a bug. What version? Can you prepare a small test case?
MapServer version 7.0.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I have tracked it down to a specific geometry:-
010200000000000000 = ‘LINESTRING EMPTY’
> From: mapserver-users <mapserver-users-bounces at lists.osgeo.org <mailto:mapserver-users-bounces at lists.osgeo.org>> on behalf of Dave Barter <dave at phased.co.uk <mailto:dave at phased.co.uk>>
> Sent: Friday, August 18, 2017 5:13:29 AM
> To: mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> Subject: [mapserver-users] Segfault - LINE layer
> This call:-
> /usr/lib/cgi-bin/mapserv.ngx -nh "QUERY_STRING=map=/usr/src/app/mapfiles/api/wms_osm_google_world_bw.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&STYLES=&BBOX=-6114.962263%2c6099063.360931%2c162657.996191%2c6267836.319384&WIDTH=276&HEIGHT=276&FORMAT=image%2fpng&SRS=EPSG%3a3857&LAYERS=roads8&transparent=false
> Is giving me:-
> Segmentation fault (core dumped)
> For the layer definition:-
> LAYER
>     GROUP "default"
>     STATUS ON
>     TYPE LINE
>     MINSCALEDENOM 1300032
>     MAXSCALEDENOM 2600064
>     NAME "roads8"
>     DEBUG 5
>     CONNECTIONTYPE postgis
>     PROCESSING "CLOSE_CONNECTION=DEFER"
>     {%public_map_user%}
>     PROJECTION
>         "init=epsg:900913"
>     END
>     DATA "geometry from (select osm_id,geometry,name as name,ref,type from mapping_osm.osm_new_roads_gen1 where type in ('trunk','motorway','primary') order by z_order asc) as foo using unique osm_id using srid=900913"
>     LABELITEM "name"
>     CLASSITEM "type"
>     CLASS
>         EXPRESSION {primary,primary_link}
>         STYLE
>             WIDTH 0.5
>             COLOR 242 242 242
>         END
>     END
>     CLASS
>         EXPRESSION "motorway"
>         TEXT ("[ref]")
>         STYLE
>            WIDTH 1
>            OUTLINEWIDTH 0.5
>            OUTLINECOLOR 217 217 217
>         END
>         STYLE
>             WIDTH 1
>             COLOR 242 242 242
>         END
>     END
>     CLASS
>         EXPRESSION "trunk"
>         TEXT ("[ref]")
>         STYLE
>            WIDTH 1
>            OUTLINEWIDTH 0.5
>         END
>         STYLE
>             WIDTH 1
>              COLOR 242 242 242
>         END
>     END
> END
> When I look in my debug file I see the following as last set of lines:-
> [Fri Aug 18 11:09:39 2017].945225 msPostGISReadShape: PQgetlength = 7
> [Fri Aug 18 11:09:39 2017].945236 msPostGISReadShape: [type] "primary"
> [Fri Aug 18 11:09:39 2017].945248 msPostGISReadShape: PQgetlength = 0
> [Fri Aug 18 11:09:39 2017].945259 msPostGISReadShape: [name] ""
> [Fri Aug 18 11:09:39 2017].945270 msPostGISReadShape: PQgetlength = 0
> [Fri Aug 18 11:09:39 2017].945281 msPostGISReadShape: [ref] ""
> [Fri Aug 18 11:09:39 2017].945292 msPostGISReadShape: Setting shape->index = 307691570
> [Fri Aug 18 11:09:39 2017].945303 msPostGISReadShape: Setting shape->resultindex = 327
> [Fri Aug 18 11:09:39 2017].945314 msPostGISReadShape: [index] 307691570
> [Fri Aug 18 11:09:39 2017].945346 msPostGISReadShape: [shape] LINESTRING (139231.1053743003285490 6233477.4797634640708566, 139274.7760105324559845 6233447.9814142314717174)
> [Fri Aug 18 11:09:39 2017].945369 msPostGISLayerNextShape called.
> [Fri Aug 18 11:09:39 2017].945383 msPostGISReadShape called.
> So it seems to segfault during  msPostGISReadShape.
> I’ve checked the query and it is pulling 3110 linestrings from the database.
> But I am not sure why is is segfaulting? Is this a bug?
> Dave Barter
> @citizenfishy
> www.phased.co.uk <http://www.phased.co.uk/>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170818/4bba0c9e/attachment-0001.html>
