[mapserver-users] Segfault - LINE layer
Andrea Peri
aperi2007 at gmail.com
Fri Aug 18 12:22:15 PDT 2017
Hi, I guess the avoid of empty or null geometries should happened surely in
wms service.
Not sure It is good in wfs services.
A.
Il 18 Ago 2017 17:19, "Lime, Steve D (MNIT)" <steve.lime at state.mn.us> ha
scritto:
Still it the code should gracefully skip empty geometries. Can you create a
ticket please?
*From:* mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] *On
Behalf Of *Dave Barter
*Sent:* Friday, August 18, 2017 9:56 AM
*To:* mapserver-users at lists.osgeo.org
*Subject:* Re: [mapserver-users] Segfault - LINE layer
As a quick workaround edit your DATA:
where type in ('trunk','motorway','primary') AND geometry is not null
-Jukka Rahkonen-
That will not work as an empty geometry is not null
The fix is WHERE NOT ST_EMPTY(geometry)
*Lähettäjä:* mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org
<mapserver-users-bounces at lists.osgeo.org>] *Puolesta *Dave Barter
*Lähetetty:* 18. elokuuta 2017 16:05
*Vastaanottaja:* mapserver-users at lists.osgeo.org
*Aihe:* Re: [mapserver-users] Segfault - LINE layer
On 18 Aug 2017, at 13:44, Lime, Steve D (MNIT) <steve.lime at state.mn.us>
wrote:
I'd call it a bug. What version? Can you prepare a small test case?
MapServer version 7.0.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I have tracked it down to a specific geometry:-
010200000000000000 = ‘LINESTRING EMPTY’
*From:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> on behalf
of Dave Barter <dave at phased.co.uk>
*Sent:* Friday, August 18, 2017 5:13:29 AM
*Subject:* [mapserver-users] Segfault - LINE layer
This call:-
/usr/lib/cgi-bin/mapserv.ngx -nh "QUERY_STRING=map=/usr/src/
app/mapfiles/api/wms_osm_google_world_bw.map&SERVICE=
WMS&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&STYLES=&
BBOX=-6114.962263%2c6099063.360931%2c162657.996191%
2c6267836.319384&WIDTH=276&HEIGHT=276&FORMAT=image%2fpng&
SRS=EPSG%3a3857&LAYERS=roads8&transparent=false
Is giving me:-
Segmentation fault (core dumped)
For the layer definition:-
LAYER
GROUP "default"
STATUS ON
TYPE LINE
MINSCALEDENOM 1300032
MAXSCALEDENOM 2600064
NAME "roads8"
DEBUG 5
CONNECTIONTYPE postgis
PROCESSING "CLOSE_CONNECTION=DEFER"
{%public_map_user%}
PROJECTION
"init=epsg:900913"
END
DATA "geometry from (select osm_id,geometry,name as name,ref,type from
mapping_osm.osm_new_roads_gen1 where type in ('trunk','motorway','primary')
order by z_order asc) as foo using unique osm_id using srid=900913"
LABELITEM "name"
CLASSITEM "type"
CLASS
EXPRESSION {primary,primary_link}
STYLE
WIDTH 0.5
COLOR 242 242 242
END
END
CLASS
EXPRESSION "motorway"
TEXT ("[ref]")
STYLE
WIDTH 1
OUTLINEWIDTH 0.5
OUTLINECOLOR 217 217 217
END
STYLE
WIDTH 1
COLOR 242 242 242
END
END
CLASS
EXPRESSION "trunk"
TEXT ("[ref]")
STYLE
WIDTH 1
OUTLINEWIDTH 0.5
END
STYLE
WIDTH 1
COLOR 242 242 242
END
END
END
When I look in my debug file I see the following as last set of lines:-
[Fri Aug 18 11:09:39 2017].945225 msPostGISReadShape: PQgetlength = 7
[Fri Aug 18 11:09:39 2017].945236 msPostGISReadShape: [type] "primary"
[Fri Aug 18 11:09:39 2017].945248 msPostGISReadShape: PQgetlength = 0
[Fri Aug 18 11:09:39 2017].945259 msPostGISReadShape: [name] ""
[Fri Aug 18 11:09:39 2017].945270 msPostGISReadShape: PQgetlength = 0
[Fri Aug 18 11:09:39 2017].945281 msPostGISReadShape: [ref] ""
[Fri Aug 18 11:09:39 2017].945292 msPostGISReadShape: Setting shape->index
= 307691570
[Fri Aug 18 11:09:39 2017].945303 msPostGISReadShape: Setting
shape->resultindex = 327
[Fri Aug 18 11:09:39 2017].945314 msPostGISReadShape: [index] 307691570
[Fri Aug 18 11:09:39 2017].945346 msPostGISReadShape: [shape] LINESTRING
(139231.1053743003285490 6233477.4797634640708566, 139274.7760105324559845
6233447.9814142314717174)
[Fri Aug 18 11:09:39 2017].945369 msPostGISLayerNextShape called.
[Fri Aug 18 11:09:39 2017].945383 msPostGISReadShape called.
So it seems to segfault during msPostGISReadShape.
I’ve checked the query and it is pulling 3110 linestrings from the database.
But I am not sure why is is segfaulting? Is this a bug?
Dave Barter
@citizenfishy
www.phased.co.uk
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170818/e8962566/attachment.html>
