[mapserver-users] Multi template
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Wed Aug 23 09:07:33 PDT 2017
Yes, you can have both although whenever I've started to use the outputformat-based templating I've abandoned the other approach. If no query format is set then MapServer will revert to the older approach. You can't, however, mix and match the approaches within a single query response. Does that make sense?
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of pe_lord
Sent: Wednesday, August 23, 2017 10:51 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Multi template
One more question.
Can template-output-driven be able to live at the same time as other
standard templates? Until now, it seems to me that supplant the behavior of
the other.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Multi-template-tp5317599p5332275.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
