[mapserver-users] Mapserver 7.0.6 from MS4W does not find spatial index from Spatialite
Even Rouault
even.rouault at spatialys.com
Fri Aug 25 12:14:37 PDT 2017
On vendredi 25 août 2017 12:32:14 CEST Rahkonen Jukka (MML) wrote:
> Hi,
> I have a Spatialite database which has a valid and consistent spatial index
> if I ask spatialite-gui to check it. However Mapserver 7.0.6 from MS4W
> 3.2.2 does not find it.
> Layer is defined as
> CONNECTIONTYPE OGR
> DEBUG 5
> CONNECTION "\ms4w_data\apps\wms-wfs.sqlite"
> DATA "select * from states"
> [Fri Aug 25 15:17:41 2017].225000 OGROPen(\ms4w_data\apps\wms-wfs.sqlite)
> [Fri Aug 25 15:17:41 2017].235000
> msConnPoolRegister(states,\ms4w_data\apps\wms-wfs.sqlite,00A0F2D0) [Fri Aug
> 25 15:17:41 2017].236000 msOGRFileOpen(): Layer select * from states has
> spatial index disabled [Fri Aug 25 15:17:41 2017].236000
> msOGRFileWhichShapes: SQL = select * from states WHERE
> MbrIntersects("Geometry",
> BuildMbr(-110.556532,27.919128,-78.556643,44.907341)).
> I wonder what is the check that is performed. Obviously not either of these
> two:
> select spatial_index_enabled from geometry_columns where
> f_table_name='states'; returns 1
> select checkspatialindex('states','geometry');
There's this test that is done:
char* pszRequest = NULL;
pszRequest = msStringConcatenate(pszRequest,
"SELECT * FROM sqlite_master WHERE type = 'table' AND name = 'idx_");
psInfo->pszSpatialFilterTableName);
pszRequest = msStringConcatenate(pszRequest, "_");
OGR_L_GetGeometryColumn(psInfo->hLayer));
pszRequest = msStringConcatenate(pszRequest, "'");
So it checks the existence of idx_{tablename}_{geometryname} table, but in a case sensitive
way. Here I see from the MbrIntersects() call that the geometry name is Geometry, so I guess
it tries idx_states_Geometry, but that actual name must be idx_states_geometry.
Can you retry by putting the table and geometry column name in lower case ?
If that works, the test should likely be fixed to be case insensitive.
> returns 1
> -Jukka Rahkonen-
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170825/7a15eb7c/attachment.html>
