[mapserver-users] Georeferencing a raster without worldfile
Richard Greenwood
richard.greenwood at gmail.com
Fri Dec 1 09:55:34 PST 2017
On Fri, Dec 1, 2017 at 9:50 AM, Trond Michelsen <
trondmm-mapserver+2017 at crusaders.no> wrote:
> Thank you for the suggestion. Unfortunately, I forgot to mention that
> they're png-files.
> Trond Michelsen
> On Fri, Dec 01, 2017 at 04:38:38PM +0000, Fawcett, David (MNIT) wrote:
> > If these are .tif files, can you write the georeference info to internal
> metadata as a way to avoid a .tfw file?
> > -----Original Message-----
> > From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
> On Behalf Of Trond Michelsen
> > Sent: Friday, December 01, 2017 10:19 AM
> > To: Mapserver <mapserver-users at lists.osgeo.org>
> > Subject: [mapserver-users] Georeferencing a raster without worldfile
> > Hi.
> > I'm using mapserver 7.0.0
> > I have about 250.000 raster images that I want to serve through
> mapserver. They are all 1195x1550 pixels, and they all cover the exact same
> area (UTM33N -75000,6450000,1120000,8000000). All images has a
> resolution of 1km per pixel.
> > I also have a worldfile that works:
> > --8<--
> > 1000
> > 0.0
> > 0.0
> > -1000
> > -75000
> > 8000000
> > --8<--
> > What I want to avoid, is to have one worldfile for each of the 250.000
> files.
> > I have tried to use a processing directive, like the documentation says:
> > --8<--
> > WORLDFILE=<file>
> > Specifies an alternative world file (for georeferencing). If a
> > path only is specified, the base name of the dataset will be
> > appended. The suffix (.wld / .tfw / ...) can be omitted.
> > Example:
> > PROCESSING "WORLDFILE=/path/"
> > or
> > PROCESSING "WORLDFILE=/path/file.wld"
> > or
> > PROCESSING "WORLDFILE=/path/file"
> > --8<--
> > But adding
> > PROCESSING "WORLDFILE=/path/to/my/worldfile.wld"
> > to my mapfile has, as far as I can tell, absolutely no effect.
> > The projection on the layer is defined like this:
> > PROJECTION
> > "+init=epsg:32633"
> > END
> > If I change that to
> > PROJECTION
> > "+init=epsg:32633 +units=km"
> > END
> > My layer will turn up at 0,0,1195000,1550000 in EPSG:32633
> > In theory, if I added easting and northing to the projection definition,
> like this:
> PROJECTION
> > "+init=epsg:32633 +units=km +x_0=-75000 +y_0=6450000"
> > END
> > It should position itself properly, but proj does not allow easting or
> northing to the UTM projections.
You can specify the full proj style definition instead of the
"init=epsg:xxxx" format. So maybe something like:
PROJECTION
+proj=tmerc
+lat_0=0.0
+lon_0=15 # not sure this is correct long0 is for zone 33
+x_0=-75000
+y_0=6450000
+a=6378137.0
+b=6356752.3141403
+datum=WGS84
+units=km
END
> The documetation also states:
> > --8<--
> > wms_extent
> > For Rasters served through WMS, MapServer can now use the
> > wms_extent metadata parameter to register the image. If a .wld
> > file cannot be found, MapServer will then look for the wms_extent
> > metadata parameter and use the extents of the image and the size
> > of the image for georegistration.
> > --8<--
> > However, if I add
> > METADATA
> > "wms_extent" "-75000 6450000 1120000 8000000"
> > END
> > to the layer, it has no effect.
> > So... What am I doing wrong? How do I get my files to show up where
> they're supposed to?
> > Trond Michelsen
> > mapserver-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171201/1a99f187/attachment-0001.html>
