[mapserver-users] msGEOSError(): GEOS library error when using MULTILINESTRING (( mercator ))
Gert Cuykens
gert.cuykens at gmail.com
Fri Dec 1 17:15:12 PST 2017
The example below gives a msGEOSError(): GEOS library error
To reproduce create a shapefile put MULTILINESTRING mercator data in
it and use shp2img to see the error messages, Note that
MULTILINESTRING with wgs data in it works, which makes me think it
could be maybe the length of a multiline string that generates the
error? Because mercator is much bigger.
Example mapserver 7.0.6
OGRFeature(test):178
color (String) = #c6b952
MULTILINESTRING ((1365999.913051389390603
6668002.688304415903986,1365929.670452698832378
6667981.874043367803097),(1366036.091885895933956
6668063.352393131703138,1365999.913051389390603
6668002.688304415903986),(1366004.811108984053135
6668127.219178147614002,1366036.091885895933956
6668063.352393131703138),(1365934.123232331126928
6668138.427049811929464,1366004.811108984053135
6668127.219178147614002),(1365862.878758222097531
6668117.612443232908845,1365934.123232331126928
6668138.427049811929464),(1365792.190881569404155
6668094.485164736397564,1365862.878758222097531
6668117.612443232908845),(1365384.093628322007135
6667942.914158684201539,1365306.949221200309694
6667931.172859975136817),(1365461.460674423491582
6667952.342789551243186,1365384.093628322007135
6667942.914158684201539),(1365538.939040013123304
6667961.771431289613247,1365461.460674423491582
6667952.342789551243186),(1365616.528725096955895
6667969.065293673425913,1365538.939040013123304
6667961.771431289613247),(1365773.266568133374676
6668049.120308448560536,1365760.910104657290503
6668084.344763254746795),(1365771.819414753001183
6668087.724895685911179,1365792.190881569404155
6668094.485164736397564),(1365760.910104657290503
6668084.344763254746795,1365771.819414753001183
6668087.724895685911179),(1365694.786327125271782
6667973.512773931957781,1365616.528725096955895
6667969.065293673425913),(1365773.043929153587669
6667977.426558562554419,1365694.786327125271782
6667973.512773931957781),(1365851.301531179109588
6667980.272948558442295,1365773.043929153587669
6667977.426558562554419),(1365929.670452698832378
6667981.874043367803097,1365851.301531179109588
6667980.272948558442295))
