[mapserver-users] wms_enable_request header vs. layer
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Thu Dec 7 06:36:26 PST 2017
Moin,
I think the problem is, that the Layers allow the GetMap-Request and
MapServer does not provide the required Information in the capabilities.
Am I wrong?
Jörg
Am 07.12.2017 um 11:30 schrieb Passmore, James H.:> Technically QGIS (or
any other client) is going against the WMS standard by requesting
something not in GetCapabilities response, and MapServer is at fault for
responding with something not advertised.
> Of course a GetMap operation is mandatory for a WMS, so you might argue that MapServer is at fault for providing a GetCapabilities response that doesn't advertise a GetMap operation.
> James
> -----Original Message-----
> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of mapserver-users-request at lists.osgeo.org
> Sent: 06 December 2017 20:00
> To: mapserver-users at lists.osgeo.org
> Subject: mapserver-users Digest, Vol 119, Issue 5
> Send mapserver-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> mapserver-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific than "Re: Contents of mapserver-users digest..."
> Today's Topics:
> 1. wms_enable_request header vs. layer (Jörg Thomsen (WhereGroup))
> Message: 1
> Date: Wed, 6 Dec 2017 13:41:36 +0100
> From: Jörg Thomsen (WhereGroup) <joerg.thomsen at wheregroup.com>
> To: "mapserver-users at lists.osgeo.org"
> <mapserver-users at lists.osgeo.org>
> Subject: [mapserver-users] wms_enable_request header vs. layer
> Message-ID: <4dccde7c-ce96-e22a-af43-718d4631a8bb at wheregroup.com>
> Content-Type: text/plain; charset=utf-8
> Hi,
> I need an explanation for ows_enable_request.
> There are two mapfiles, brw_enable_header.map and brw_enable_layer.map The only difference is, that in brw_enable_header.map I have enabled all ows requests within the metadata-section in the header and in each layer.
> In brw_enable_layer.map I only have enabled all requests in the layer-section, but not in the header.
> Both WMS allow the capability-request and in brw_enable_layer.map the information for the wms-request is missing:
> https://www.diffchecker.com/KjsX2Wbk
> OK. The brw_enable_layer.map (with no ows_enable_reqeust in the header) allows GetMap-Requests:
> http://h2743629.stratoserver.net/cgi-bin/mapserv?map=/data/ows/map/brw_enable_layer.map&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=48.60086340827337636,9.02229999999999954,48.65160000000000196,9.0733134442446044&CRS=EPSG:4326&WIDTH=426&HEIGHT=422&LAYERS=bodenrichtwertzone&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE
> I think this is technically correct, but as the capabilities don't provide any information for the getMap-Request (no online-ressource, no image-formats), a client does not know this parameters. In the result I cannot load the WMS into a mabpender-application.
> I wonder why (and I am surprised) QGIS doesn't have any problems with this wms.
> Is this how it shall be? Is MapServer working correct or Mapbender? Or both, but ...?
> Regards, Jörg
> Where2B Konferenz 2017
> 14. Dezember 2017 in Bonn
> www.where2b-conference.com
> Subject: Digest Footer
> End of mapserver-users Digest, Vol 119, Issue 5
> ________________________________
> This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
Viele Grüße,
Jörg Thomsen
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 89 09 53 21
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
