[mapserver-users] php mapscript set opacity
Sven Schroeter
schroeter at netgis.de
Tue Dec 12 05:51:09 PST 2017
Hi Carlos,
thank you very much, that was the trick and it works great.
Here is my new code (tested with MS 7.07):
if(ms_GetVersionInt() >= 70000){
$this_layer->updateFromString('LAYER COMPOSITE OPACITY '.$my_layeropacity.' END END');
}else{
$this_layer->set('opacity', $my_layeropacity);
Greetings
Sven
Von: Carlos Ruiz [mailto:boolean10001 at yahoo.com]
Gesendet: Samstag, 9. Dezember 2017 00:58
An: Sven Schroeter
Betreff: Re: [mapserver-users] php mapscript set opacity
Hi Sven,
I guess this happens because of the new COMPOSITE block:
COMPOSITE
OPACITY 100
END
I remember that I had the same problem, and I had to use $layer->updateFromString() to set the opacity. As far as I can recall, this is a known issue, no methods to change opacity nor composite are available for PHP mapscript.
On Friday, December 8, 2017, 2:20:06 AM CST, Sven Schroeter <schroeter at netgis.de> wrote:
I'm trying to transfer old code from Mapserver 6 to Mapserver 7 and fail to
set the transparency via PHP Mapscript.
my code:
$this_layer->set('opacity', 80); Works with MS 6, not in MS 7 (the layer
is not displayed here)
$this_layer->set('opacity', 100); Works with MS 6 and MS 7
I have read the Migration guide, but I don't know what to do with it in this
case.
Thanks
Sven
mapserver-users mailing list
mapserver-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
