[mapserver-users] mapserver with kml
Seth G
sethg at geographika.co.uk
Thu Dec 14 04:55:37 PST 2017
Interesting!
>From the WMS spec: "Graphic element formats include Scalable
Vector Graphics (SVG; MIME type “image/svg+xml”) or Web Computer
Graphics Metafile (WebCGM; MIME type
“image/cgm;Version=4;ProfileId=WebCGM”) formats"
I wonder how many WMS clients would handle KML as a WMS. As it is XML
then it would't be accessible from another domain in a web client.
Ivan's problem looks to be a projection issue only.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Thu, Dec 14, 2017, at 10:42 AM, Rahkonen Jukka (MML) wrote:
> Hi Seth,
> KML is considered as an image format and it should work with WMS and
> with mode=map
> http://mapserver.gis.umn.edu/fr/development/rfc/ms-rfc-58.html>
> It seems that KML output has not been developed much since the initial
> implementation.>
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users [mailto:mapserver-users-
> bounces at lists.osgeo.org] *Puolesta *Seth G *Lähetetty:* 14. joulukuuta
> 2017 10:03 *Vastaanottaja:* mapserver-users at lists.osgeo.org *Aihe:*
> Re: [mapserver-users] mapserver with kml>
> Hi,
> Your output image looks like a projection issue. Google Maps use the
> espg:3857 projection, but your request is asking for SRS=epsg:4326,
> maybe try changing this?> Also are you trying to return KML or display an image using KML as a
> data source? If you are trying to return KML you'd need to use WFS
> rather than WMS which only returns images.>
> Seth
> On Thu, Dec 14, 2017, at 01:33 AM, Ivan Ogasawara wrote:
>> Dear all,
>> Anyone knows some tutorial to work with mapserver (wms) and kml?
>> I am trying to do it .. but with no success.
>> this is the local url used:
>> http://172.17.0.2/?map=/maps/dengue-Rio-de-Janeiro.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=RIO_DE_JANEIRO&STYLES=&SRS=epsg:4326&BBOX=-43.7965385309,-23.0828926973,-43.0990394004,-22.7460202858&WIDTH=400&HEIGHT=300&FORMAT=kml.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=RIO_DE_JANEIRO&STYLES=&SRS=epsg:4326&BBOX=-43.7965385309,-23.0828926973,-43.0990394004,-22.7460202858&WIDTH=400&HEIGHT=300&FORMAT=kml>>
>> for image/png works fine (tested with leaflet).
>> Any tips?
>> Files:
>> * mapfiles:
>> * https://pastebin.com/4EkahMZi
>> * https://pastebin.com/DVSt4mmS
>> * kml: https://pastebin.com/LYkD4ZDL
>> * Result:
>> https://user-images.githubusercontent.com/5209757/33969313-f7029096-e042-11e7-8621-e8235f0bd5ce.png>>
>> Thanks!
>> My best regards,
>> Ivan
>> _________________________________________________
>> mapserver-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171214/549d28c5/attachment-0001.html>
