[mapserver-users] Error with Filter = no results
Seth G
sethg at geographika.co.uk
Thu Feb 2 05:06:57 PST 2017
Hi Daniel,
Does setting the EXTENT for your map or layer make any difference?
Also try adding the projections you want to use to the MAP METADATA
section.
"wfs_srs" "EPSG:32632 EPSG:4326"
Regards,
Seth
On 02/02/2017 10:19, Daniel Hardes wrote:
> Same query without srsName. I tried it with WFS 1.0.0, 1.1.0, 2.0.0
> and no results.
> Am 02.02.2017 um 09:33 schrieb Rahkonen Jukka (MML):
>> What happens if you remove srsName from the filter? It can be hard to know how to reproject from EPSG:32632 into unknown. WFS 1.0.0 is anyway tied to the default srs. I would also consider saving data into PostGIS with proper SRID.
>> -Jukka Rahkonen-
>> ----- Alkuperäinen viesti -----
>> Lähettäjä: "Daniel Hardes"<hardes at 3dis.de>
>> Lähetetty: 2.2.2017 10:22
>> Vastaanottaja:"mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
>> Aihe: [mapserver-users] Error with Filter = no results
>> Hello,
>> i have a question with the Filter parameter.
>> without a filter, mapserver does a normal SQL query like:
>> select "pkid","set","id","lod","type","source","referencepoint","boundingbox",encode(ST_AsBinary(ST_Force_2D("groundsurface"),'NDR'),'hex') as geom,"id" from building where groundsurface && ST_GeomFromText('POLYGON((691642.41999 5334989.72599,691642.41999 5335172.82301,691979.17301 5335172.82301,691979.17301 5334989.72599,691642.41999 5334989.72599))',-1) limit 101
>> but if i add an BBox filter, i got a wrong polygon:
>> select "pkid","set","id","lod","type","source","referencepoint","boundingbox",encode(ST_AsBinary(ST_Force_2D("groundsurface"),'NDR'),'hex') as geom,"id" from building where groundsurface && ST_GeomFromText('POLYGON((-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785))',-1) and (st_intersects(groundsurface,ST_GeomFromText('POLYGON ((691813.1405204038600000 5335101.3663145527000000, 691813.1405204038600000 5335921.3585226759000000, 692960.5523786536700000 5335921.3585226759000000, 692960.5523786536700000 5335101.3663145527000000, 691813.1405204038600000 5335101.3663145527000000))',-1)) = TRUE)
>> ... The polygon:
>> is wrong. A normal SQL query without these values, gets my desired result.
>> My map File:
>> MAP
>> NAME "sample"
>> SIZE 800 400
>> DEBUG 5
>> OUTPUTFORMAT
>> NAME "geojson"
>> DRIVER "OGR/GEOJSON"
>> MIMETYPE "application/json; subtype=geojson"
>> FORMATOPTION "STORAGE=stream"
>> FORMATOPTION "FORM=SIMPLE"
>> END
>> CONFIG MS_ERRORFILE "ms_error.log"
>> PROJECTION
>> "init=epsg:32632"
>> END
>> WEB
>> METADATA
>> ows_enable_request "*"
>> END
>> END
>> LAYER
>> DEBUG 5
>> NAME "poly"
>> STATUS DEFAULT
>> TYPE POLYGON
>> METADATA
>> "wfs_srs" "EPSG:32632"
>> "wms_transparent" "true"
>> "wfs_getfeature_formatlist" "geojson"
>> END
>> PROJECTION
>> 'init=epsg:32632'
>> END
>> CONNECTIONTYPE postgis
>> CONNECTION "host=localhost port=5432 user=postgres password=xxxxx dbname=map_daniel"
>> DATA "groundsurface from building using SRID=-1 using unique id"
>> CLASS
>> STYLE
>> COLOR "#88888888"
>> ANTIALIAS true
>> END
>> END
>> END
>> END
>> And the Request:
>> http://localhost:8081/cgi-bin/mapserv.exe?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRSNAME=EPSG:32632&TYPENAMES=poly&COUNT=100&outputformat1=geojson&map=C:\Users\d.hardes\Documents\map.map&Filter=<Filter><BBOX><PropertyName>poly</PropertyName><Box srsName="EPSG:32632"> <coordinates>691813.1405204039,5335101.366314553 692960.5523786537,5335921.358522676</coordinates></Box></BBOX></Filter>
>> And result
>> <?xml version='1.0' encoding="UTF-8" ?>
>> <wfs:FeatureCollection
>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>> xmlns:wfs="http://www.opengis.net/wfs"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/wfs
>> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
>> http://localhost:8081/cgi-bin/mapserv.exe?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=poly&OUTPUTFORMAT=XMLSCHEMA">
>> <gml:boundedBy>
>> <gml:null>missing</gml:null>
>> </gml:boundedBy>
>> </wfs:FeatureCollection>
>> where is the Error in my settings?
> 3DIS GmbH <http://www.3dis.de>
> Daniel Hardes
> Mail: hardes at 3dis.de <mailto:kalkofen at 3dis.de>| Tel.: +49 (0)2861 8919 84
> 3DIS GmbH
> Konrad-Zuse-Straße 6 D - 46397 Bocholt
> www.3dis.de <http://www.3dis.de>
> 3DIS GmbH | Geschäftsführung: Gerrit Hoven, Andreas Steffens |
> Amtsgericht Coesfeld | HRB 12986
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
web: http://geographika.co.uk
twitter: @geographika
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170202/4cf6fc7c/attachment-0001.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170202/4cf6fc7c/attachment-0001.png>
