[mapserver-users] setting bounding box WG84
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Feb 8 02:25:35 PST 2017
You are not supposed to set it manually. TinyOWS is making a database query for finding the extents. You can configure it to use the faster method http://postgis.net/docs/manual-2.0/ST_Estimated_Extent.html if you set it in the config file http://mapserver.org/tinyows/configfile.html.
In your case I suppose that the table behind tows:poiserver is empty.
It might be good to use titles like “[TinyOWS] Setting bounding box WG84” because all Mapserver users are not TinyOWS users.
-Jukka Rahkonen-
Hi All,
How ´would I set the WGS84 Bounding box in the server ?
<FeatureType><Name>tows:poiserver</Name>
<Title>poi server database</Title>
<DefaultSRS>urn:ogc:def:crs:EPSG::4326</DefaultSRS>
<ows:WGS84BoundingBox>
<ows:LowerCorner>0 0</ows:LowerCorner>
<ows:UpperCorner>0 0</ows:UpperCorner>
</ows:WGS84BoundingBox>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170208/fc6702a4/attachment-0001.html>
