[mapserver-users] Cant get polygon labels to show up
Brent Fraser
bfraser at geoanalytic.com
Mon Feb 13 20:15:26 PST 2017
Try using
CLASS
TEXT '[LOCATION]'
LABEL
instead of LABELITEM?
Best Regards,
Brent Fraser
On 2/13/2017 8:46 PM, Stephen Woodbridge wrote:
> As a Followup, I used a hex editor to change the column name to
> uppercase and that did not change anything so its not a case probelm
> as far as I can tell.
> -SteveW
> On 2/13/2017 10:32 PM, Stephen Woodbridge wrote:
>> On 2/13/2017 3:19 PM, Basques, Bob (CI-StPaul) wrote:
>>> try lowercase “location” for the LABELITEM . . .
>> Yeah, I tried that also. The tileindex file was created by gdaltindex
>> and a hexdump on the .dbf does show it is lowercase. This is running on
>> mapserver 7.0.4.
>> I have tried everything I can think of at least twice but can't get it
>> to label or throw any error message.
>> I'm wondering if something in mapserver 7.0 changed in regards to
>> matching shapefile DBF columns. At any rate I would expect some kind of
>> error if there is a problem.
>> I can provide the shapefile if someone is interested in checking it out.
>> This one has me totally stumped.
>> -Steve W
>>> bobb
>>>> On Feb 13, 2017, at 2:17 PM, Stephen Woodbridge
>>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>> I have a tileindex for a bunch of DOQQs and I would like to create a
>>>> layer the displays there filenames and bboxes. I'm using the tileindex
>>>> shapefile as my data source like with the layer definition below.
>>>> The BBox polygon lines are showing up but I must be doing something
>>>> stupid because I can not get the labels to display. And there are no
>>>> errors in the log file.
>>>> Any ideas?
>>>> LAYER
>>>> NAME "doqq_bbox"
>>>> STATUS ON
>>>> TYPE POLYGON
>>>> DATA "ca_naip_2014_quads/doqq-tileindex"
>>>> PROJECTION "init=epsg:4326" END
>>>> LABELITEM "LOCATION"
>>>> PROCESSING "LABEL_NO_CLIP=ON"
>>>> CLASS
>>>> STYLE
>>>> OUTLINECOLOR "#ff0000"
>>>> WIDTH 0.5
>>>> END
>>>> LABEL
>>>> FONT "arial"
>>>> TYPE TRUETYPE
>>>> SIZE 14
>>>> WRAP '/'
>>>> ALIGN CENTER
>>>> POSITION CC
>>>> COLOR "#880000"
>>>> OUTLINECOLOR "#ffffff"
>>>> OUTLINEWIDTH 3
>>>> PARTIALS TRUE
>>>> FORCE TRUE
>>>> END
>>>> END
>>>> END
>>>> This email has been checked for viruses by Avast antivirus software.
>>>> https://www.avast.com/antivirus
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> “There is nothing quite so useless as doing with great efficiency
>>> something that should not be done at all.”
>>> - Peter Drucker
