[mapserver-users] Possible application questions
Joe Hogan
joehogan at gmx.com
Tue Feb 21 08:14:22 PST 2017
Hello Steve,
Thanks for the reassuring news. We have found our possible solution.
The CRM software has not yet been modified, but it will have the two
fields for the Longitude and Latitude.
Other fields will be used as well, and we will have to add more for those.
When you say it has to provide wms/wfs services, what does that mean? I
found the 9nitials, but what does it mean?
Is it a special format? Like I need to export the data from the data
base into a certain format?
Sorry for the newbie questions, but I am learning:)
Thanks
Joseph
On 02/21/2017 08:48 AM, Steve.Toutant at inspq.qc.ca wrote:
> hi Joseph
> Yes mapserver can be used for your application by providing wms/wfs
> services
> Here are some links that can help
> #connect to mysql
> http://mapserver.org/input/vector/mysql.html
> #filters...Runtime substitution
> http://mapserver.org/cgi/runsub.html
> Do you have latitude/longitude data in your database, or any other
> georeference that can be used to render on a map?
> Steve
> -----"mapserver-users" <mapserver-users-bounces at lists.osgeo.org> a
> écrit : -----
> A : mapserver-users at lists.osgeo.org
> De : Joe Hogan
> Envoyé par : "mapserver-users"
> Date : 20/02/2017 11:12
> Objet : [mapserver-users] Possible application questions
> Hello,
> I am writing to ask if MapServer will work for our application.
> We are working on a project that will allow us to place on a map of our
> country various projects. We want to be able to filter them based on
> various pieces of information, including, for example:
> year of project
> population
> project budget
> etc...
> We are compiling the data in a CRM(MySQL database), and want to use the
> data from the CRM to feed the mapping software.
> 1 - can I map the type fo information that I need?
> 2 - can we use the data directly from the CRM database if we tell the
> mapping software what data to use(so t can be read on the fly, live from
> the database?), or does it need to be exported before using in the
> mapping software?
> 3 - It it needs to be in its own exported format, how to I get it from
> MtSQL to the correct format?
> Thanks for any and all help.
> Joseph
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Si vous n'êtes pas le destinataire de ce message, veuillez le détruire
> près avoir informé l'expéditeur de son erreur. Par ailleurs, il est
> interdit de copier ou de modifier ce courriel sans l'autorisation de
> l'auteur.
> L'Institut national de santé publique du Québec n'assume aucune
> responsabilité à l'égard du contenu des messages personnels envoyés
> par ses employés.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170221/014508b1/attachment-0001.html>
