[mapserver-users] Σχετ: WMS service doesn't work
Stefanos Anastasiou
emperor_stef at yahoo.gr
Wed Feb 22 03:29:42 PST 2017
Hello Gorank, I see you've set the DEBUG object in the map level. Does it give you any report? If not do you get any errors in your browser ?
-Stefanos
Στις 10:52 π.μ. Τετάρτη, 22 Φεβρουαρίου 2017, ο/η gorank <kirandziskig at gmail.com> έγραψε:
I have a problem with connection to wms service and don't now what is the
problem.
The URL is :
http://makstat.stat.gov.mk:8080/cgi-bin/GDZS/wms?map=/ms4w/apps/GDZS/NASA.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=Getcapabilities
Maybe the problem is the .map file below
MAP
CONFIG "MS_ERRORFILE" "C:\ms4w\Apache\cgi-bin\GDZS\Error.txt"
DEBUG 5
EXTENT 7446477 4453517 7682148 4763251
FONTSET "ttf-fonts/fonts.txt"
IMAGETYPE "png"
NAME "MapStatDZS"
SHAPEPATH "data/"
SIZE 800 600
UNITS METERS
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
FORMATOPTION "QUALITY=95"
END # OUTPUTFORMAT
PROJECTION
"init=epsg:6316"
END # PROJECTION
LEGEND
KEYSIZE 30 17
KEYSPACING 10 10
LABEL
FONT "arial"
SIZE 10
COLOR 0 0 89
ENCODING "iso-8859-5"
OFFSET 0 -3
SHADOWSIZE 5 1
TYPE TRUETYPE
END # LABEL
STATUS ON
TRANSPARENT FALSE
END # LEGEND
QUERYMAP
SIZE -1 -1
STATUS ON
STYLE HILITE
END # QUERYMAP
SCALEBAR
INTERVALS 4
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
SIZE 200 3
STATUS OFF
UNITS MILES
END # SCALEBAR
WEB
IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_srs" "EPSG:6316 EPSG:4326 EPSG:3909"
"wms_onlineresource"
"http://makstat.stat.gov.mk:8080/cgi-bin/GDZS/wms?map=/ms4w/apps/GDZS/NASA.map&"
"wms_encoding" "utf-8"
"wms_title" "StatMap"
END # METADATA
#TEMPLATE "C:/ms4w/Apache/cgi-bin/goki/tretTemplejt.html"
END # WEB
LAYER
DATA "NASA.shp"
LABELITEM "NAZIVOP_MK"
LABELMAXSCALEDENOM 443652
METADATA
"wms_enable_request" "*"
"wfs_enable_request" "*"
"coordsys_name" "Macedonia State Coordinate System zone 7"
"wms_title" "Opstini"
#"default_godina" "2010"
END # METADATA
NAME "Opstini"
PROJECTION
"proj=tmerc"
"lat_0=0"
"lon_0=21"
"k=0.9999"
"x_0=7500000"
"y_0=0"
"ellps=bessel"
"towgs84=551.7,162.9,467.9,6.04,1.96,-11.38,-4.82"
"units=m"
"no_defs"
END # PROJECTION
STATUS ON
TEMPLATE "query"
TILEITEM "location"
TYPE POLYGON
UNITS METERS
#VALIDATION
# "godina" "^[12][09][0-9][0-9]$"
#END #VALIDATION
CLASS
NAME "klasa_1"
EXPRESSION ([2011] > 0 and [2011] < 5)
LABEL
FONT "maccswiss"
SIZE 8
#ENCODING "iso-8859-5"
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE TRUETYPE
END # LABEL
STYLE
COLOR 255 255 128
OUTLINECOLOR 130 130 130
WIDTH 0.5
END # STYLE
TITLE "4.9 или помалку"
END # CLASS
CLASS
NAME "klasa_2"
EXPRESSION ([2011] >= 5 and [2011] < 10)
LABEL
FONT "maccswiss"
SIZE 8
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE TRUETYPE
END # LABEL
STYLE
COLOR 250 209 85
WIDTH 0.5
END # STYLE
TITLE "5.0 - 9.9"
END # CLASS
CLASS
NAME "klasa_3"
EXPRESSION ([2011] >=10 and [2011] < 15)
LABEL
FONT "maccswiss"
SIZE 8
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE TRUETYPE
END # LABEL
STYLE
COLOR 242 167 46
WIDTH 0.5
END # STYLE
TITLE "10.0 - 14.9"
END # CLASS
CLASS
NAME "klasa_4"
EXPRESSION ([2011] >= 15 and [2011] < 20)
LABEL
FONT "maccswiss"
SIZE 8
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE TRUETYPE
END # LABEL
STYLE
COLOR 173 83 19
WIDTH 0.5
END # STYLE
TITLE "15.0 - 19.9"
END # CLASS
CLASS
NAME "klasa_5"
EXPRESSION ([2011] >= 20 and [2011] < 10000)
LABEL
FONT "maccswiss"
SIZE 8
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE TRUETYPE
END # LABEL
STYLE
COLOR 107 0 0
WIDTH 0.5
END # STYLE
TITLE "20 и повеќе"
END # CLASS
END # LAYER
LAYER
DATA "REGIONI2007_NASA.shp"
METADATA
"wms_title" "Regioni"
END # METADATA
NAME "Regioni"
PROJECTION
"proj=tmerc"
"lat_0=0"
"lon_0=21"
"k=0.9999"
"x_0=7500000"
"y_0=0"
"ellps=bessel"
"units=m"
"no_defs"
END # PROJECTION
STATUS ON
TEMPLATE "query"
TILEITEM "location"
LABELITEM "NAZIV_NTES"
TYPE POLYGON
UNITS METERS
CLASS
NAME "Reg"
LABEL
FONT "maccswiss"
SIZE 14
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE TRUETYPE
END # LABEL
STYLE
OUTLINECOLOR 20 20 20
END # STYLE
END # CLASS
END # LAYER
LAYER
DATA "DrzGran_NASA.shp"
METADATA
"wms_title" "DrzavnaGranica"
END # METADATA
NAME "DrzGran"
PROJECTION
"proj=tmerc"
"lat_0=0"
"lon_0=21"
"k=0.9999"
"x_0=7500000"
"y_0=0"
"ellps=bessel"
"units=m"
"no_defs"
END # PROJECTION
STATUS ON
TEMPLATE "query"
TILEITEM "location"
TYPE LINE
UNITS METERS
CLASS
NAME "Drzag"
LABEL
SIZE SMALL
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
STYLE
OUTLINECOLOR 50 50 50
WIDTH 1.9
END # STYLE
END # CLASS
END # LAYER
LAYER
DATA "EZERA_NASA.shp"
METADATA
"wms_title" "Ezera"
END # METADATA
NAME "Ezera"
PROJECTION
"proj=tmerc"
"lat_0=0"
"lon_0=21"
"k=0.9999"
"x_0=7500000"
"y_0=0"
"ellps=bessel"
"units=m"
"no_defs"
END # PROJECTION
STATUS ON
TEMPLATE "query"
TILEITEM "location"
TYPE POLYGON
UNITS METERS
CLASS
NAME "Ezera"
LABEL
SIZE SMALL
OFFSET 0 0
POSITION CC
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
STYLE
OUTLINECOLOR 0 158 219
WIDTH 0.91
END # STYLE
STYLE
COLOR 199 234 251
END # STYLE
END # CLASS
END # LAYER
END # MAP
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-service-doesn-t-work-tp5308980.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170222/25fbe96d/attachment-0001.html>
