[mapserver-users] Mapserver - libs in /usr/local/lib disappear after reboot
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jan 4 11:32:17 PST 2017
I haven't seen the libs-physically-disappear case, but I often reboot
client servers and the libs 'cannot be found' (meaning executing mapserv
doesn't search for the libs in the proper directory of /usr/local/lib/).
  In this case the solution is to set the LD_LIBRARY_PATH to that
directory for your profile (this step changes for different linux
flavors) and then re-run 'sudo ldconfig'.
As a side note, for good karma please refrain from sending your
questions to multiple mailing lists at the same time.  Thanks,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-01-04 2:36 PM, Ian Walberg wrote:
> Folks,
> We build and install from source any of the recent versions using cmake.
> Then we copy the mapserv binary from /usr/local/bin to /var/www/cgi-bin to use with our apache install.
> All is good unless we reboot and the libs in /usr/local/lib are removed, this is a Fedora 19 server.
> Anyone know why this happens? What have we done wrong?
> Thanks
> Ian
