[mapserver-users] wms/ows_enabe request and invalid layer and Qgis
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Jan 10 07:44:01 PST 2017
Have a look at the access.log and check what request QGIS has sent. And even 10.210.1.32 does not seem to be open to internet it is not a good habit to reveal your passwords in mailing lists. I suggest to change that password everywhere you are using it.
Another thing to check is if the "wms_onlineresource" is correct for just this mapfile. QGIS is using the advertised URL for GetMaps if you do not select "Ignore GetMap/GetTile URI reported in capabilities". Is this your current mapfile or the one that you copied?
http://127.0.0.1:8080/cgi-bin/mapserv.exe?MAP=C:/ms4w/map/prescr_test.map
-Jukka Rahkonen-
Here's my map file :
MAP
NAME "Mapserver"
FONTSET "./fonts/fonts.txt"
OUTPUTFORMAT
NAME "png"
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
END #fin format
EXTENT 679286.0 6153539.5 679580.0 6153724.6 #xmin ymin xmax ymax
UNITS METERS
DEBUG 5
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
CONFIG MS_ERRORFILE "C:/ms4w/errorMapFile.txt"
PROJECTION # proj de sortie
"init=epsg:2154"
END
WEB
METADATA
"wms_title" "WMS, aide au montage des opérations"
http://127.0.0.1:8080/cgi-bin/mapserv.exe?MAP=C:/ms4w/map/prescr_test.map"
"wms_enable_request" "*" #active les getcapabilities, getmap, getfeatureinfo, getfeature
"wms_srs" "EPSG:2154 EPSG:3857 EPSG:900913"
"wms_encoding" "UTF-8"
END #fin metadata
END #end web
LAYER
NAME "prescriptions"
#STATUS ON
TYPE POLYGON
PROJECTION
"init=epsg:2154"
END #fin projection
CONNECTIONTYPE POSTGIS
CONNECTION "host=10.210.1.32 dbname=activite user=PostGIS
password=CAVIAR2016 port=5432"
DATA "geom from (select gid, geom, numope, numprescr, annee, nomope, ro, typope from activite.prescription) as foo using unique gid SRID=2154"
PROCESSING "CLOSE_CONNECTION=DEFER"
MAXSCALEDENOM 80000
LABELITEM "numprescr"
CLASS
STYLE
COLOR 200 125 0
OPACITY 50
OUTLINECOLOR 200 125 0
WIDTH 1
LINECAP round
END #end Style
LABEL
FONT "verdana"
SIZE 4
COLOR 0 0 0
OUTLINECOLOR 255 255 255
OUTLINEWIDTH 1
POSITION auto #uc
MAXSCALEDENOM 80000
TYPE truetype
END #fin label
TEMPLATE "bidon.html"
END #fin class
METADATA
"gml_include_items" "all"
"wms_title" "prescriptions"
#"wms_srs" "EPSG:2154"
END #fin metadata prescriptions
END #fin layer prescriptions
END
I have a correct image in Firefox. But in QGIS I can't get anything, it says
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter. A layer might be disabled for this request. Check wms/ows_enable_request settings.
Layer name is right.
Besides this layer is just a copy of another one working perfectly, with the request available ! So I can't figure out the reason why I can't display this layer.
Any idea ?
View this message in context: http://osgeo-org.1560.x6.nabble.com/wms-ows-enabe-request-and-invalid-layer-and-Qgis-tp5302807.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
