[mapserver-users] Postgres call 2 GetCapabilities attribute listing.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Jan 10 09:11:35 PST 2017
Hi Jeff,
PHP = Yucky!!
I was trying to go the route of all OGC calls. The idea is to possibly expand on the options for configuring GeoMOOSE, where you would be able to configure a filtering process on a layer by layer basis. I know I can make it all work by hardcoding things. It’s just that the data is variable from the database (as it should be) and I wanted to be able to populate the distinct list upon query vs hardcoding it.
The SLD path might be the best “OGC” based approach, but it end up as a two stage query this way. I’m still investigating things. Maybe I should just hardcode for the first pass and try some different approaches after the fact. Hmm, a thought, I could use a Template populated from a SQL call for the list, but it’s not OGC anymore . . .
I have many potential uses for this on a layer by layer basis.
Thanks for the response.
bobb
On Jan 10, 2017, at 10:50 AM, Jeff McKenna <jmckenna at gatewaygeomatics.com<mailto:jmckenna at gatewaygeomatics.com>> wrote:
Hi Bob,
I personally think you are over-complicating this: if you have full access to the PG instance, it's easiest to have your form submit a short PHP script (mapscript isn't even needed) that executes a "pg_query" returning your distinct column names.
That's the easiest way.
If you must stick with WMS etc, you could use a mapscript wrapper to capture something like a GetFeatureInfo request (that lists all attributes) and populate your form (see wrapper doc http://mapserver.org/ogc/mapscript.html).
But if this was me I would create a short pg_query script.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-01-10 11:52 AM, Basques, Bob (CI-StPaul) wrote:
All,
Anyone have an example of how to set up a postgres call in mapfile that
is used to output a GetCapabilities attribute listing? I think I said
that correctly. :c)
I have a layer set up as a WMS service from Postgres, I want to provide
a GetCapabilities result for a “select distinct column” call to populate
a layering filtering form. Is this even a WMS thing?
I anticipate that this particular set of unqiue values will be added to
over time in the database and thus without my knowing it. I think I
could generate a SLD on the fly with the list as a call result, but that
seems overly complicated for some reason.
Maybe this is a DescribeLayer function?? Or do I need to move to a WFS
service?
Thanks
bobb
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
"Not everything that can be counted counts, and not everything that counts can be counted."
- Albert Einstein
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170110/835c97e7/attachment.html>
