[mapserver-users] WMS T time series data support
Schepers, Benjamin schepers at rvr-online.de
Wed Jan 11 07:45:09 PST 2017
Hey,
hmmmm, debugging can be an awful thing…..
Always have a look at the logs (error, etc.).
I’d suppose, that mapserver can’t find the tiles.
A valid DIMENSION-Element in GetCapabilities could look like this:
<Dimension name="time" units="ISO8601" default="2016" nearestValue="0">2009/2016/P1Y</Dimension>    <-- in this case the dataset supports time from 2009-2016 in one-year-steps]
Are you really sure about the right relations on paths? See:
http://mapserver.org/optimization/tileindex.html#tileindex
I can’t see any “SHAPEPATH” (directory of index), which is referenced in MAP-section, see:
http://mapserver.org/mapfile/map.html [from mapserver-docs: … Normally the location should contain the path to the tile file relative to the shapepath, not relative to the tileindex itself. … ]
What also works for me is using absolute paths:
Please try the the absolute path to tileindex, e.g.:
TILEINDEX "/data/subfolder/index"
My index-file also contains absolute paths to tiff-files
<Is the TILEINDEX property in the map file the name of the shape file or the name of a PostGIS table?
Both (and still more) ways are possible, for example SpatiaLite-Layer (OGR-Connection), other layers from same mapfile…
Hope, it helps
Ben
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170111/91dec814/attachment.html>
