[mapserver-users] Mapserver seem change the line size in raster dataset
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Jan 13 02:17:09 PST 2017
What is included in "any setting I know on mapserver"? Could you show a link to some raster, together with the LAYER from your mapfile?
-Jukka Rahkonen-
Hi, I have a raster dataset to publish on internet using mapserver wms.
This dataset is a rasterization of some thematic datasets.
After publish it, I notice a difference between the map returned from mapserver and reproduced on qgis and the map reproduced using qgis accessing directly the same raster.
I try any setting I know on mapserver but without be able to obtain the same image.
To show the diffrence I capture the screenshot of both as visible on qgis:
This is the sample of the raster on qgis retrieve from mapserver wms:
https://www.dropbox.com/s/464cg3c91b5twpz/from-mapserver-scale800000.gif?dl=0
This instead is the sample of the raster on qgis retrieve directly from the raster accessed directly from qgis.
https://www.dropbox.com/s/ai9p3ntnkcmp9zt/from-qgis-scale800000.gif?dl=0
The colors are the same, the difference is in the lines. That qgis desktop version has the lines more defined instead the mapserver version has lines reduced.
Any hint is welcome,
Thx
Andrea Peri
qwerty àèìòù
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
