[mapserver-users] PHP/MapScript applySLD() bottleneck
Sergio Segala
sergio.segala.list at gmail.com
Tue Jan 17 02:03:57 PST 2017
Hi Sushrut,
thanks for answer. I can try to split the SLD, apply the fragment to the
right layer, and see the performance difference.
Sergio
On 01/16/2017 03:18 PM, Sushrut Shivaswamy wrote:
> Hey Sergio,
> The definition of mapObject - > applySLD() in the map server
> documentation is as follows.
> int applySLD(string sldxml)*
> *Apply the SLD document to the map file. *
> *The matching between the sld document and the map file will be done
> using the layer’s name.*
> *See SLD HowTo for more information on the SLD support.*
> Assuming that your SLD document is applied to every layer in the
> mapfile I see two potential areas for bottle necks to appear.
> Since the mapping between SLD and layer is based on the layer name,
> what could be happening is that for every NamedLayer occurence
> in your SLD, mapserver must be iterating over all the layers in the
> map file to see which layer name matches the name in the SLD.
> For 76 occurences( as stated by you) *this would become an order
> n-squared complexity search.*
> *Unless mapserver has an internal hash-table like structure to
> associate a layerName with layerObj which I doubt, this would take a
> lot of time*
> *and request processing times would scale on n-squared basis where n
> is the the number of NamedLayerOccurences.*
> The actual styling of a layer based on SLD shouldn't increase the time
> all that much.
> Could you try applying the SLD on a lyer basis instead of for the
> whole map.
> If you have reference to the actual layerObj you could just call
> layerObj - > applySLD().
> This should cut down the time involved in searching through the entire
> map file for a LAYER reference with matching layer name.
> Regards,
> Sushrut Shivaswamy
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170117/316a8844/attachment.html>
