[mapserver-users] Mapfile CLASS hierarchy
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jan 21 19:03:40 PST 2017
Within a layer objects are always drawn in the order they are delivered
from the datasource. Think of the CLASSes are an IF-ELSEIF-BLOCK, when
an object is presented each CLASS is tested and the first one the
accepts the object renders it.
I often up a default class at then end that has no expression ans render
it in red just so I can see if I missed any cases, but remove it when
I'm done developing the mapfile.
-Steve W
On 1/21/2017 8:48 PM, Stefanos Anastasiou wrote:
> Hi list,
> according to the documentation, the first layer in the mapfile is
> drawn first, and the second is drawn on top of that and so on... I was
> wondering if the same principle applies to the CLASS object as well. For
> example: I have a "Roads" layer stored in PostGIS with a "Category"
> column representing the different types of roads. So a category 3 is
> very small roads, category 2 is city roads, 1 is major roads and 0 is
> highways and on the same layers I create four CLASS objects with
> different styles for each Road category. But regardless the order of the
> classes (either I draw the small roads first or the highways) the same
> effect insists: the small roads are drawn over the highways. So what
> is the solution here? Create different layers of the same dataset
> representing the various values of the "Category" column ??
> Regards,
> -Stefanos
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
