[mapserver-users] 3D / 2.5D / Coordinates with Z and GEOMETRY Type in WFS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jul 4 13:46:44 PDT 2017
Before this past long weekend I was testing with Windows and getting
about a 1% difference; but I didn't report it here because I was using
the 'wallclock' time and not CPU time, on Windows. (that was with
Even's 200 map draw test) I personally feel that the difference is so
minimal now that yes, we should enable SUPPORTS=POINT_Z_M for the next
MS4W release.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-07-03 4:49 AM, Daniel Hardes wrote:
> Do we need more testing or could "USE_POINT_Z_M = ON" the default in the
> next release?
>> Even Rouault <even.rouault at spatialys.com> hat am 30. Juni 2017 um
>> 16:40 geschrieben:
>> On vendredi 30 juin 2017 09:59:30 CEST Daniel Morissette wrote:
>> > On 2017-06-30 9:50 AM, Even Rouault wrote:
>> > > I'm wondering if we shouldn't revisit the decision to have
>> USE_POINT_Z_M
>> > > disabled by default. This is often annoying.
>> > > Apparently, adding USE_POINT_Z_M defaulting to OFF was driven by
>> > > performance reasons per
>> > > https://github.com/mapserver/mapserver/issues/1244 . But this was 12
>> > > years ago. Perhaps with recent hardware the performance difference
>> isn't
>> > > that big. The ticket unfortunately doesn't contain a test case to
>> bench
>> > > (likely lots of lines/polygons, or large lines/polygons to render). If
>> > > the perf difference is still there, a more involved change would be
>> > > indeed to move the z and m components into separate arrays.
>> > #1244 refers to #1224 which is using the gmap demo mapfile... which is a
>> > relatively small dataset, so it should be easy to verify if the issue is
>> > still relevant on more recent hardware using gmap or probably any other
>> > dataset.
>> > https://github.com/mapserver/mapserver-import/issues/1224
>> OK, I downloaded
>> http://dl.maptools.org/dl/gmap-ms46.tar.gz
>> (not sure if there's a more uptodate version of it).
>> Added the necessary MAP and SYMBOLSET keywords in the mapfile and
>> symbolset file.
>> With master, compiled in Release (-O3)
>> and the following Python mapscript bench.py
>> import mapscript
>> for i in range(200):
>> map = mapscript.mapObj('gmap75.map')
>> img1 = map.draw()
>> I ran it 10 times consecutively with each config and took the smallest
>> time ("real" figure)
>> With USE_POINT_Z_M=OFF
>> time python bench.py
>> real 0m4.167s
>> user 0m3.964s
>> sys 0m0.200s
>> With USE_POINT_Z_M=ON
>> real 0m4.252s
>> user 0m3.972s
>> sys 0m0.260s
>> So USE_POINT_Z_M=ON is 2% slower than OFF
>> On a recent (~ 1 year old) laptop with a
>> Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
