[mapserver-users] mapserver, msProjectPoint() error
Vu, Johnson (EC) johnson.vu at canada.ca
Mon Jul 10 16:31:30 PDT 2017
I'm a student working on a webapp that uses mapserv 6.4.1. I've been getting this error in my ms_error.txt and I'm having trouble finding the cause. At first I thought it was a problem with my extents, so I verified all of them with my .shp files and everything was OK. I am using epsg:4326 as my projection. I've bolded the two errors I've been seeing the most. They fill the error log when I click on a region on the map.
Does anyone know possible causes for the error I've posted below? I'm very new to mapserv and would appreciate any help.
wxo_mapserv/tmp_output/ms_error.txt:
[Mon Jul 10 23:06:29 2017].538763 msProjectPoint(): Projection library error. proj says: latitude or longitude exceeded limits
[Mon Jul 10 23:06:29 2017].538797 msProjectPoint(): Projection library error. proj says: latitude or longitude exceeded limits
[Mon Jul 10 23:06:29 2017].538813 msProjectRect(): some points failed to reproject, doing internal sampling.
[Mon Jul 10 23:06:29 2017].539124 mapserv request processing time (msLoadMap not incl.): 0.352s
[Mon Jul 10 23:06:29 2017].539162 msFreeMap(): freeing map at 0x2188de0.
[Mon Jul 10 23:06:35 2017].301195 CGI Request 1 on process 31628
[Mon Jul 10 23:06:35 2017].302266 msWFSParseRequest(): WFS post request: <GetFeature                        service="WFS"
               version="1.1.0"                        srsName="EPSG:900913"                        xmlns:topp="http://www.openplan
s.org/topp"                        xmlns:wfs="http://www.opengis.net/wfs"                        xmlns:ogc="http://www.opengis.net
/ogc"                        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"                        xsi:schemaLocation="http
://www.opengis.net/wfs                         http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">                        <Query
typeName="clc_he_site_e" srsName="EPSG:900913">                            <Filter><Intersects>                                <Pr
opertyName>the_geom</PropertyName>                                <Point srsName="EPSG:900913">
<coordinates>-11383613.748454727,6924094.039571445</coordinates>                                </Point>
   </Intersects></Filter>                        </Query>                    </GetFeature>
[Mon Jul 10 23:06:35 2017].303829 msProjectPoint(): Projection library error. proj says: tolerance condition error
[Mon Jul 10 23:06:35 2017].303882 msProjectPoint(): Projection library error. proj says: tolerance condition error
[Mon Jul 10 23:06:35 2017].303909 msProjectPoint(): Projection library error. proj says: tolerance condition error
[Mon Jul 10 23:06:35 2017].303954 msProjectPoint(): Projection library error. proj says: tolerance condition error
"msProjectPoint(): Projection library error. proj says: tolerance condition error"                              <- repeats several hundred lines
"msProjectPoint(): Projection library error. proj says: latitude or longitude exceeded limits"     <- repeats several hundred lines
Post Request param:
<GetFeature xmlns:ogc="http://www.opengis.net/ogc" xmlns:topp="http://www.openplans.org/topp" xmlns:wfs="http://www.opengis.net/wfs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" service="WFS" version="1.1.0" srsName="EPSG:900913" xsi:schemaLocation="http://www.opengis.net/wfs                         http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd<http://www.opengis.net/wfs                        %20http:/schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd>">
   <Query typeName="clc_he_site_e" srsName="EPSG:900913">
      <Filter>
         <Intersects>
            <PropertyName>the_geom</PropertyName>
               <coordinates>-11452101.325798245,7031717.375396973</coordinates>
            </Point>
         </Intersects>
      </Filter>
   </Query>
</GetFeature>
Thanks,
Johnson
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170710/9d94c11a/attachment.html>
