[mapserver-users] mapserver, msProjectPoint() error
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jul 11 05:08:59 PDT 2017
Hi Johnson,
Welcome to the MapServer community.
Regarding those errors, here are some rules that I always follow, that
may help your case:
- when serving through WMS/WFS etc, always make sure to remove all
errors from a GetCapabilities response first (in your case, there might
be warnings of missing metadata such as "wfs_srs").
- try not to use a non-standard projection (EPSG:900913 was officially
replaced by EPSG:3857 https://epsg.io/3857), you're just asking for
possible trouble down the road if you do...
- just to see if these errors are related to a projection, possibly
setup a test case where your source data is in 4326, you serve the data
through WFS in 4326, and your client-side application requests the data
in 4326 (and see if those errors still exist)
- possibly set the EXTENT values for the map object to the whole world:
-180 -90 180 90
- test your mapfile locally with the shp2img commandline utility
(http://mapserver.org/utilities/shp2img.html)
Other notes:
I have seen odd projection errors like yours before, somehow being
caused in a client-side javascript application requesting WMS/WFS
layers. In my case I believe the maps were generated fine, so I might
have 'lived' with those errors, not sure.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-07-10 8:31 PM, Vu, Johnson (EC) wrote:
> Hi,
> I’m a student working on a webapp that uses mapserv 6.4.1. I’ve been
> getting this error in my ms_error.txt and I’m having trouble finding the
> cause. At first I thought it was a problem with my extents, so I
> verified all of them with my .shp files and everything was OK. I am
> using epsg:4326 as my projection. I’ve bolded the two errors I’ve been
> seeing the most. They fill the error log when I click on a region on the
> map.
> Does anyone know possible causes for the error I’ve posted below? I’m
> very new to mapserv and would appreciate any help.
> wxo_mapserv/tmp_output/ms_error.txt:
> [Mon Jul 10 23:06:29 2017].538763 msProjectPoint(): Projection library
> error. proj says: latitude or longitude exceeded limits
> [Mon Jul 10 23:06:29 2017].538797 msProjectPoint(): Projection library
> [Mon Jul 10 23:06:29 2017].538813 msProjectRect(): some points failed to
> reproject, doing internal sampling.
> [Mon Jul 10 23:06:29 2017].539124 mapserv request processing time
> (msLoadMap not incl.): 0.352s
> [Mon Jul 10 23:06:29 2017].539162 msFreeMap(): freeing map at 0x2188de0.
> [Mon Jul 10 23:06:35 2017].301195 CGI Request 1 on process 31628
> [Mon Jul 10 23:06:35 2017].302266 msWFSParseRequest(): WFS post request:
> <GetFeature service="WFS"
> version="1.1.0"
> srsName="EPSG:900913" xmlns:topp="http://www.openplan
> s.org/topp"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:ogc="http://www.opengis.net
> /ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
> <Query
> typeName="clc_he_site_e"
> srsName="EPSG:900913">
> <Filter><Intersects> <Pr
> opertyName>the_geom</PropertyName> <Point
> <coordinates>-11383613.748454727,6924094.039571445</coordinates>
> </Point>
> </Intersects></Filter>
> </Query> </GetFeature>
> [Mon Jul 10 23:06:35 2017].303829 msProjectPoint(): Projection library
> error. proj says: tolerance condition error
> [Mon Jul 10 23:06:35 2017].303882 msProjectPoint(): Projection library
> [Mon Jul 10 23:06:35 2017].303909 msProjectPoint(): Projection library
> [Mon Jul 10 23:06:35 2017].303954 msProjectPoint(): Projection library
> *“msProjectPoint(): Projection library error. proj says: tolerance
> condition error” <- repeats several hundred
> lines*
> *“msProjectPoint(): Projection library error. proj says: latitude or
> longitude exceeded limits” <- repeats several hundred lines*
> Post Request param:
> <?xml version="1.0"encoding="UTF-8"?>||
> <GetFeaturexmlns:ogc="http://www.opengis.net/ogc"xmlns:topp="http://www.openplans.org/topp"xmlns:wfs="http://www.opengis.net/wfs"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"service="WFS"version="1.1.0"srsName="EPSG:900913"xsi:schemaLocation="http://www.opengis.net/wfs
> <http://www.opengis.net/wfs %20http:/schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd>">||
> ||<QuerytypeName="clc_he_site_e"srsName="EPSG:900913">||
> ||<Filter>||
> ||<Intersects>||
> ||<PropertyName>|the_geom|</PropertyName>||
> ||<PointsrsName="EPSG:900913">||
> ||<coordinates>|-11452101.325798245,7031717.375396973|</coordinates>||
> ||</Point>||
> ||</Intersects>||
> ||</Filter>||
> ||</Query>||
> </GetFeature>
> Thanks,
> Johnson
