[mapserver-users] Fwd: Zoom to something and display in one shot from MapServer CGI.
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jul 11 11:06:32 PDT 2017
Bobb,
If you using sql you can do this in one pass, just write a trivial php
script that returns an image.
1. connect to db
2. sql to query expanded bbox of parcel
select st_astext(st_extent(st_expand(geom, delta)))
from parcels where pin=?
3. create url to mapserver based on bbox and image size
5. header('Content-type: image/png');
4. passthru(url);
Don't make it more complicated than it needs to be. You can do the same
using perl, python, script language of your choice.
-Steve
On 7/11/2017 12:22 PM, Basques, Bob (CI-StPaul) wrote:
>> Hi Steve,
>> I want to send a CGI request like : ServerName?pin=202923230045
>> And zoom to the pin (parcel polygon) in the returned image and also
>> add a buffer percentage. This is for a reporting application. I can
>> do it with an intermediate service, but it’s been awhile since I did
>> this, and was wondering if anything new in MapServer might help with
>> this for a single pass approach.
>> The zoom parameters would be hardcoded into the MapFILE in an ideal
>> world, I can build an SQL for this for example, but I recall I
>> couldn’t use the BBOX returned from the SQL as a BBOX for Mapserver
>> parent call, my memory is cloudy on that capability from MapServer
>> though, hence the question. Now that you have me talking it through
>> though, I think the last time I asked about this it was to inquire
>> about possibly chaining more than one MapServer call together to get
>> the result. I think there were fears at the time about possible
>> runaway processes being created . . . .
>> bobb
>>> On Jul 11, 2017, at 10:38 AM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>> On 7/11/2017 10:39 AM, Basques, Bob (CI-StPaul) wrote:
>>>> All,
>>>> It’s probably because it’s Tues. but I think I’ve asked this before
>>>> in the past . . .
>>>> I have a DB with PIN numbers for PARCELS and I want to be able to
>>>> auto-zoom(with buffer) to a PARCEL by just sending in a PIN number
>>>> via CGI.
>>>> can the BBOX be pulled from the DB based on the geom in one shot?
>>>> I’ve done this in the past with a Webservice that went and grabbed
>>>> the BBOX separately, then assembled the url for getting the graphic
>>>> back from Mapserver.
>>> Bobb,
>>> What are you trying to zoom? the image or the client?
>>> If it is the client then how is mapserver on the server supposed to
>>> tell the client it needs to zoom? You have to query the server to get
>>> the bbox then make the client zoom appropriately.
>>> For the image, assuming you want a static image showing the parcel,
>>> then I would write a php/python/perl script the you pass the PIN to
>>> and it does the work to figure out the extents and return the image.
>>> -Steve W
>>> This email has been checked for viruses by Avast antivirus software.
>>> https://www.avast.com/antivirus
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> "If you're going through hell, keep going. “
>> - Winston Churchill
> "Be nice to people on your way up because you meet them on your way down."
> - Jimmy Durante
