[mapserver-users] MS4W version 3.2.2 available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jul 13 09:06:10 PDT 2017
Hello everyone,
MS4W version 3.2.2 is now available at http://www.ms4w.com This
contains security releases of Apache, PHP, and upgrades to the MapServer
7.0.6 & GDAL 2.2.1 releases. Several changes were also made to
libraries for performance improvements (such as libjpeg-turbo and
SQLite). Several packages were upgraded for the installer including
GeoMOOSE 3.0.0-beta (new backend engine, give it a try!), Mapbender
3.0.6.1 (now super fast), OpenLayers 4.2.0 (when you goto the OpenLayers
examples page and search for "mapserver" you can find a local MS4W
example). This a substantial MS4W release. Here is the full list of
changes:
- upgraded MapServer and MapScript (CSharp, Java, Python, PHP) to 7.0.6
- upgraded GDAL to 2.2.1 (trac ticket 111)
- upgraded PHP to 5.6.31 (trac ticket 122)
- upgraded Apache to 2.4.27 (trac ticket 119)
- enabled OPcache PHP extension for Mapbender performance (trac
ticket 63)
- built MapServer with support for Z geometry values (trac ticket 120)
- updated cURL certificates bundle
- rebuilt mod_fcgid
- rebuilt Apache H264 Streaming Module
- rebuilt MapCache
- rebuilt TinyOWS
- changed JPEG library to libjpeg-turbo (trac ticket 121)
- upgraded libPNG support to 1.6.29
- upgraded libTIFF support to 4.0.8 (trac ticket 114)
- upgraded GeoTIFF support to SVN-trunk-20170623
- rebuilt HDF4 support
- upgraded HDF5 support to 1.10.1
- upgraded PostgreSQL support to 9.6.3
- upgraded MySQL support to 5.7.18
- upgraded SQLite support to 3.19.3 (trac ticket 107)
- rebuilt SpatiaLite support
- upgraded OpenSSL support to 1.0.2l (trac ticket 116)
- upgraded cURL support to 7.54.1
- added curl.exe utility into /tools
- rebuilt NetCDF support
- upgraded Freetype support to 2.8
- upgraded Cairo support to 1.14.10
- rebuilt Poppler support
- upgraded to Esri File Geodatabase 1.5 API support (trac ticket 109)
- upgraded to Oracle SDK 12.2.0.1.0
- upgraded PCRE support to 8.40
- upgraded HarfBuzz support to 1.4.6
- rebuilt libSVG support
- rebuilt libSVG-Cairo support
- upgraded Shapelib support to 1.4.0 (trac ticket 72)
- rebuilt shp2tile utility
- renamed Apache access and error log files
Please note that (if you are using the .zip) your server must have the
C++ Redistributable installed on it beforehand: execute the local file
/ms4w/tmp/vcredist_x86.exe
Please don't be afraid to also provide feedback and requests through the
MS4W tracker (so the comments and requests are not lost or forgotten):
http://www.ms4w.com/trac/
Thank you all for sharing your spatial information with MS4W.
And happy MapServing!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
