[mapserver-users] rotating a label 90 degrees.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Mon Jul 31 13:56:30 PDT 2017
Steve,
I’m pretty sure I can get to what I need via SQL, but it would be rather convoluted. It’s doable though.
I was hoping for doing something like “auto+/-90” as an option for a value.
bobb
On Jul 31, 2017, at 3:52 PM, Lime, Steve D (MNIT) <steve.lime at state.mn.us<mailto:steve.lime at state.mn.us>> wrote:
I can’t think of anything offhand. If using PostGIS could you compute the angle and add 90? I think you could then use attribute binding on the result. Could pre-process data too. Otherwide we’d need an “angleoffset” parameters or something like that.
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Monday, July 31, 2017 1:38 PM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] rotating a label 90 degrees.
All,
Is there and way to label a line with the ANGLE value set to AUTO, but to rotate the label by 90 degrees? I want to label a line by crossing perpendicular to the line vs aligned parallel.
Thanks
bobb
"In the end, it's not the years in your life that count. It's the life in your years.”
- Abraham Lincoln
"I've had a wonderful time, but this wasn't it."
- Groucho Marx
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170731/0d39d1d3/attachment.html>
