[mapserver-users] Class maxscaledenom performance
Eichner, Andreas - SID Andreas.Eichner at sid.sachsen.de
Fri Jun 2 00:57:01 PDT 2017
What about http://mapserver.org/development/rfc/ms-rfc-86.html ?
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im
> Auftrag von pe_lord
> Gesendet: Donnerstag, 1. Juni 2017 19:26
> An: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Class maxscaledenom performance
> I've verified if the issue was not linked to WMS. shp2img succeed to
> produce
> the png. But it's quite long.
> I have tried at
> *1:102 000 *
> PGIS Query = 4 sec
> Nb of recors = 2859 records
> Mapserver render by WMS = 2.5 sec
> Mapserver render by shp2img =  shp2img total time: 3.677s
> select
> "classitem_field",encode(ST_AsBinary(ST_Force2D("the_geom"),'NDR'),'hex'
> ) as
> geom,"ogc_fid" from ori_pee
> where the_geom && ST_GeomFromText('POLYGON((-8871026
> 6114309.70958512,-8871026 6140241.29041488,-8834701
> 6140241.29041488,-8834701 6114309.70958512,-8871026
> 6114309.70958512))',3857)
> *1:1 002 000*
> PGIS Query = 26 minutes
> Nb of records = 242832 records
> Mapserver render by WMS = "internal server error" = timout
> Mapserver render by shp2img =  shp2img total time: 156.299s
> select
> ) as
> where the_geom && ST_GeomFromText('POLYGON((-9031284
> 5999904.71459227,-9031284 6254645.28540772,-8674443
> 6254645.28540772,-8674443 5999904.71459227,-9031284
> 5999904.71459227))',3857)
> Here my validations
> 1-My layer have EXTENT
> 2-Mapserver do not reproject data
> 3-My layer has no label
> 4-Myconnection on postgis "DEFER"
> 5-My table have no OIDS
> 6-My table have GIST index on the_geom field
> 7-My table have a btree index on classitem field.
> 8-No warning in my GetCapabilities
> I have tried loading a new table with OIDS set to TRUE (on table, not on
> database)  and it's seem to be the same behavior? Do I really need to
> modify
> postgresql.conf?
> When I read the query called from mapserver, I think there is a way to
> improve performance on maxscaledenom. Do you think there is a way for
> mapserver to know which class to render at current scale (based on bbox
> and filter on them ...
> the query might look like this:
> select
> ) as
> 5999904.71459227))',3857) and classitem_field = 'BBOX'
> I think I will work on union layers :) .
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Class-
> maxscaledenom-performance-tp5322521p5322693.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
