[mapserver-users] Mapserver 7.0.5, PostGIS and Query Errors
James Colannino
crankycyclops at gmail.com
Wed Jun 7 18:23:14 PDT 2017
I've done some more digging, and I've realized we're using PHP Mapscript to
further configure the map tiles that are coming back.
I'm using the mapfile to generate a map object in PHP using:
$map = ms_newMapObj(mapfile_filename);
I then get the layer using:
$map->getLayer(0);
Finally, I set filters on the layer like this:
$layer->setFilter(...);
The filters being passed are native filters, and I see from the
documentation that behavior regarding native filters has changed. I think
this might be related to my problem. Does anyone know if the setFilter
function accepts native filters as of Mapserver 7, and if not, if there's
an equivalent function that does? I couldn't find it when referring to the
Mapscript API.
Thank you so much!
On Wed, Jun 7, 2017 at 10:02 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Try adding FILTER "t" and see if that fixes the issue. If it does, please
> write it up as a bug.
> -Steve W
> On 6/7/2017 3:27 AM, Jörg Thomsen (WhereGroup) wrote:
>> Hi,
>> had the same problem a few weeks ago. The solution was to fix the FILTER
>> or EXPRESSION within the classes. I don't remember exactly...
>> Jörg
>> Am 07.06.2017 um 08:45 schrieb James Colannino:
>>> Hi everyone,
>>> I have a problem that's got me stumped.
>>> I have the following layer defined in a mapfile:
>>> LAYER
>>> NAME "aggregates"
>>> TYPE POLYGON
>>> CONNECTIONTYPE POSTGIS
>>> CONNECTION "host=localhost port=5432 dbname=*** user=***
>>> password=***"
>>> DATA "geom FROM (SELECT b.geom AS geom, a.peril_id, a.portfolio_id,
>>> a.tiv, a.thematic_tiv, a.aggregates_id FROM schema.aggregates a INNER
>>> JOIN gisdata.adm_1 b on a.gid = b.gid) AS c using SRID=4326 using unique
>>> aggregates_id"
>>> PROJECTION
>>> "proj=longlat"
>>> "ellps=WGS84"
>>> "datum=WGS84"
>>> "no_defs"
>>> END
>>> END
>>> This works perfectly on Mapserver 6.4, but on 7.0.5 it's failing (for
>>> what it's worth, I compiled 7.0.5 myself because my OS didn't have
>>> binary packages for it that supported php5-mapscript.) I turned on
>>> debugging and watched what kind of errors I was getting whenever I made
>>> tile requests. Here's what I found:
>>> [Wed Jun 7 03:42:43 2017].502983 msDrawMap(): rendering using
>>> outputformat named png (AGG/PNG).
>>> [Wed Jun 7 03:42:43 2017].503018 msDrawMap(): WMS/WFS set-up and query,
>>> 0.000s
>>> [Wed Jun 7 03:42:43 2017].523359 msPostGISLayerWhichShapes(): Error
>>> (ERROR: syntax error at or near ")"
>>> LINE 1: ...2300166285,129.462890606979 36.6292300166285))',4326) and ()
>>> ) executing query: select
>>> "thematic_tiv",encode(ST_AsBinary(ST_Force2D("geom"),'NDR'),'hex') as
>>> geom,"aggregates_id" from (SELECT b.geom AS geom, a.peril_id,
>>> a.portfolio_id, a.tiv, a.thematic_tiv, a.aggregates_id FROM
>>> portfolios.aggregates a INNER JOIN gisdata.adm_1 b on a.gid = b.gid) AS
>>> c where geom && ST_GeomFromText('POLYGON((129.462890606979
>>> 36.6292300166285,129.462890606979 68.6423395678331,179.999999974944
>>> 68.6423395678331,179.999999974944 36.6292300166285,129.462890606979
>>> [Wed Jun 7 03:42:43 2017].523377 msPostGISLayerWhichShapes(): Query
>>> error. Error executing query. Check server logs
>>> [Wed Jun 7 03:42:43 2017].523434 msDrawMap(): Image handling error.
>>> Failed to draw layer named 'area_aggregates_tiv'.
>>> [Wed Jun 7 03:42:43 2017].523927 msFreeMap(): freeing map at
>>> 0x560aa573b6c0.
>>> That "and ()" at the end of the query causing the syntax error is very
>>> strange. It's like it's adding on a blank filter. I tried making the
>>> query as simple as possible, so I created another table that contained
>>> all the required information and changed the DATA line to:
>>> DATA "geom from portfolios.area_aggregates_join using SRID=4326 using
>>> unique aggregates_id"
>>> However, I still got the same type of error. I'm completely stumped.
>>> Does anyone have an idea what could be happening? I've spent the past 4
>>> hours Googling with no success.
>>> Thank you!
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Viele Grüße,
>> Jörg Thomsen
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170608/a06503da/attachment.html>
