[mapserver-users] how remove the geometry from wfs response
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 16 05:46:20 PDT 2017
Should an issue(s) be opened against this:
* for the doc?
* for adding something to the test suite?
* for the WFS non compliance with ogr?
-Steve W
On 6/16/2017 6:25 AM, Even Rouault wrote:
> On jeudi 15 juin 2017 20:22:04 CEST Andrea Peri wrote:
> > Hi,
> > I need to force the remove from the wfs response of the geometry . I need
> > to avoid that the users could take the geometry and allow only the
> > alphanumeric attributes.
> > Is this allowed from mapserver ?
> Andrea,
> Digging into the code, I found that setting in the LAYER.METADATA
> "gml_geometries" "none"
> will do the job.
> This trick is used internally in particular to implement
> GetPropertyValue. But digging into history, I actually see it was done
> on purpose for GetFeature as well per
> https://github.com/mapserver/mapserver/issues/1718
> It is just that the documentation for it in is missing in
> http://mapserver.org/ogc/wfs_server.html . Doesn't seem to be tested in
> the regression suite as far as I can see, so lucky it still works.
> Note: this trick will only work for MapServer integrated GML output. OGR
> outputformat doesn't honour this setting.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
