[mapserver-users] Mapcache segmentation faults under high load
Pieter Callewaert
pieter.callewaert at be-mobile.com
Mon Mar 6 23:02:28 PST 2017
Thanks Andreas, you brought me on a lead, indeed the ulimit for core size was on 0. Also it seems ubuntu running apport does not generate coredumps, had to change the core pattern.
I've a core dump now, checked with GDB, but not sure what I'm searching at...
http://pastebin.com/fAXdEg15
Kind regards,
Pieter C
-----Original Message-----
From: Eichner, Andreas - SID [mailto:Andreas.Eichner at sid.sachsen.de]
Sent: Monday, 6 March, 2017 15:40
To: Pieter Callewaert <pieter.callewaert at be-mobile.com>; mapserver-users at lists.osgeo.org
Subject: AW: [mapserver-users] Mapcache segmentation faults under high load
Hi Pieter,
have you checked the ulimit for the user the Apache runs under? See man core(5) for possible reasons why no core is dumped.
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
> Im Auftrag von Pieter Callewaert
> Gesendet: Montag, 6. März 2017 11:01
> An: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Mapcache segmentation faults under high
> load
> Hi Thomas,
> The documentation for debug compiling is not complete
> (http://mapserver.org/mapcache/install.html
> <http://mapserver.org/mapcache/install.html> ).
> If I add -DCMAKE_BUILD_TYPE="Debug" to the cmake, it this enough?
> Also added CoreDumpDirectory /tmp/apache2-gdb-dump to apache2.conf,
> and now I see this in the error log:
> [Thu Mar 02 08:46:42.588518 2017] [core:notice] [pid 13:tid
> 140052444931968] AH00051: child pid 14 exit signal Segmentation fault
> (11), possible coredump in /tmp/apache2-gdb-dump
> [Thu Mar 02 08:46:55.606507 2017] [core:notice] [pid 13:tid
> 140052444931968] AH00051: child pid 2097 exit signal Segmentation
> fault (11), possible coredump in /tmp/apache2-gdb-dump
> Unfortunately, no dumps yet, so I’m afraid I did something wrong with
> the debug compiling.
> Kind regards,
> Pieter C
> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> Sent: Wednesday, 1 March, 2017 09:33
> Subject: Re: [mapserver-users] Mapcache segmentation faults under high
> load
> Try to get a backtrace from the crashes by compiling mapcache in debug
> mode, and configuring apache to allow coredumps. The "stale lock"
> messages you are seeing are side effects of the crashes so that's not
> where I'd investigate at first.
> regards,
> thomas
