[mapserver-users] Mapserver GRID in degrees decimal minutes format
Pedro Venâncio
pedrongvenancio at gmail.com
Wed Mar 8 14:42:28 PST 2017
Hi Carlos,
Using C-style formatting string, I can only use %g, %f, etc., but it is
applied to Degrees component.
What I need is something like "%gº %3.2f", in whitch %gº is for the
Degrees, and %3.2f for the decimal Minutes.
Unfortunately, LABELFORMAT "DDMM" gives only the integer part of Degrees
and Minutes.
Thank you very much.
Best regards,
Pedro
2017-03-08 2:46 GMT+00:00 Carlos Ruiz <boolean10001 at yahoo.com>:
> Well, current Mapserver documentation guide says the following:
> LABELFORMAT [DD|DDMM|DDMMSS|C format string]
> Format of the label. “DD” for degrees, “DDMM” for degrees minutes, and
> “DDMMSS” for degrees, minutes, seconds. *A C-style formatting string is
> also allowed, such as “%g°” to show decimal degrees with a degree symbol.
> The default is decimal display of whatever SRS you’re rendering the GRID
> with.*
> This sounds like that is what you are looking for.
> Cheers
> *From:* Pedro Venâncio <pedrongvenancio at gmail.com>
> *To:* mapserver-users at lists.osgeo.org
> *Sent:* Tuesday, March 7, 2017 11:42 AM
> *Subject:* [mapserver-users] Mapserver GRID in degrees decimal minutes
> format
> Hi all,
> I would like to use a GRID [0], but in degrees decimal minutes
> LABELFORMAT. Something like:
> 40 46.817 -7 4.327
> Is this somehow possible in actual Mapserver version?
> Thank you very much!
> Best regards,
> Pedro Venâncio
> [0] http://mapserver.org/mapfile/grid.html
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170308/70069fc9/attachment.html>
