[mapserver-users] Mapserver GRID in degrees decimal minutes format
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Mar 8 15:19:25 PST 2017
Jeff, should this be considered a bug? --Steve
________________________________________
From: mapserver-users [mapserver-users-bounces at lists.osgeo.org] on behalf of Jeff McKenna [jmckenna at gatewaygeomatics.com]
Sent: Wednesday, March 08, 2017 4:55 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver GRID in degrees decimal minutes format
Hi Pedro,
Actually I tried yesterday with that same world countries mapfile that
was used in the map images for the examples in the documentation, and I
was unsuccessful for your exact requirements. (but I did notice a
mistake on that documentation page and fixed it yesterday!) So your
question helped improve the documentation, but I am sorry to report that
I don't believe it is possible with MapServer.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-03-08 6:42 PM, Pedro Venâncio wrote:
> Hi Carlos,
> Using C-style formatting string, I can only use %g, %f, etc., but it is
> applied to Degrees component.
> What I need is something like "%gº %3.2f", in whitch %gº is for the
> Degrees, and %3.2f for the decimal Minutes.
> Unfortunately, LABELFORMAT "DDMM" gives only the integer part of Degrees
> and Minutes.
> Thank you very much.
> Best regards,
> Pedro
> 2017-03-08 2:46 GMT+00:00 Carlos Ruiz <boolean10001 at yahoo.com
> <mailto:boolean10001 at yahoo.com>>:
> Well, current Mapserver documentation guide says the following:
> LABELFORMAT [DD|DDMM|DDMMSS|C format string]
> Format of the label. “DD” for degrees, “DDMM” for degrees
> minutes, and “DDMMSS” for degrees, minutes, seconds. *A C-style
> formatting string is also allowed, such as “%g°” to show decimal
> degrees with a degree symbol. The default is decimal display of
> whatever SRS you’re rendering the GRID with.*
> This sounds like that is what you are looking for.
> Cheers
> *From:* Pedro Venâncio <pedrongvenancio at gmail.com
> <mailto:pedrongvenancio at gmail.com>>
> *To:* mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> *Sent:* Tuesday, March 7, 2017 11:42 AM
> *Subject:* [mapserver-users] Mapserver GRID in degrees decimal
> minutes format
> Hi all,
> I would like to use a GRID [0], but in degrees decimal minutes
> LABELFORMAT. Something like:
> 40 46.817 -7 4.327
> Is this somehow possible in actual Mapserver version?
> Thank you very much!
> Best regards,
> Pedro Venâncio
> [0] http://mapserver.org/mapfile/grid.html
> <http://mapserver.org/mapfile/grid.html>
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
