[mapserver-users] Mapcache segmentation faults under high load
Eichner, Andreas - SID Andreas.Eichner at sid.sachsen.de
Thu Mar 9 02:22:48 PST 2017
Hi Pieter,
have you tried it on a different OS or just on different hardware?
To me it looks as if it happens somewhere in a C library call.
Have you a chance to try it on another OS and/or library versions?
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im
> Auftrag von Pieter Callewaert
> Gesendet: Donnerstag, 9. März 2017 09:09
> An: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Mapcache segmentation faults under high
> load
> Hi,
> I’ve been testing further, on other servers to eliminate hardware
> failures, but I keep getting consistent this problem.
> I made now consistent the same core dumps, I think my first core dump was
> not a correct one.
> http://pastebin.com/L0Lhru4m
> You can see at start:
> 1. Program terminated with signal SIGSEGV, Segmentation fault.
> 2. #0  process_socket (my_thread_num=42, my_child_num=<optimized out>,
> cs=0x7fee0d1042b8, sock=<optimized out>, p=<optimized out>, thd=<optimized
> out>)
> 3.     at event.c:1064
> If you scroll down, the last thread is this thread, but I'm not sure yet
> what the problem exactly is. Any pointers?
> Kind regards,
> Pieter Callewaert
