[mapserver-users] Mapserver GRID in degrees decimal minutes format
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Fri Mar 10 11:04:25 PST 2017
That would be best I think.
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Pedro Venâncio
Sent: Thursday, March 09, 2017 3:37 AM
To: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver GRID in degrees decimal minutes format
Hi Jeff,
Thank you very much!
Do you think it would be a good improvement to GRIDs? Should we open a feature request?
Best regards,
Pedro
2017-03-08 22:55 GMT+00:00 Jeff McKenna <jmckenna at gatewaygeomatics.com<mailto:jmckenna at gatewaygeomatics.com>>:
Hi Pedro,
Actually I tried yesterday with that same world countries mapfile that was used in the map images for the examples in the documentation, and I was unsuccessful for your exact requirements. (but I did notice a mistake on that documentation page and fixed it yesterday!) So your question helped improve the documentation, but I am sorry to report that I don't believe it is possible with MapServer.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-03-08 6:42 PM, Pedro Venâncio wrote:
Hi Carlos,
Using C-style formatting string, I can only use %g, %f, etc., but it is
applied to Degrees component.
What I need is something like "%gº %3.2f", in whitch %gº is for the
Degrees, and %3.2f for the decimal Minutes.
Unfortunately, LABELFORMAT "DDMM" gives only the integer part of Degrees
and Minutes.
Thank you very much.
Best regards,
Pedro
2017-03-08 2:46 GMT+00:00 Carlos Ruiz <boolean10001 at yahoo.com<mailto:boolean10001 at yahoo.com>
<mailto:boolean10001 at yahoo.com<mailto:boolean10001 at yahoo.com>>>:
Well, current Mapserver documentation guide says the following:
LABELFORMAT [DD|DDMM|DDMMSS|C format string]
Format of the label. “DD” for degrees, “DDMM” for degrees
minutes, and “DDMMSS” for degrees, minutes, seconds. *A C-style
formatting string is also allowed, such as “%g°” to show decimal
degrees with a degree symbol. The default is decimal display of
whatever SRS you’re rendering the GRID with.*
This sounds like that is what you are looking for.
Cheers
*From:* Pedro Venâncio <pedrongvenancio at gmail.com<mailto:pedrongvenancio at gmail.com>
<mailto:pedrongvenancio at gmail.com<mailto:pedrongvenancio at gmail.com>>>
*To:* mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
<mailto:mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
*Sent:* Tuesday, March 7, 2017 11:42 AM
*Subject:* [mapserver-users] Mapserver GRID in degrees decimal
minutes format
Hi all,
I would like to use a GRID [0], but in degrees decimal minutes
LABELFORMAT. Something like:
40 46.817 -7 4.327
Is this somehow possible in actual Mapserver version?
Best regards,
Pedro Venâncio
[0] http://mapserver.org/mapfile/grid.html
<http://mapserver.org/mapfile/grid.html>
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170310/60aedde6/attachment-0001.html>
