[mapserver-users] Mapfile XML conversion
aimdev aimdev at mail.com
Sun Mar 12 08:52:19 PDT 2017
Hi
I am currently manually converting my mapfile into xml syntax for ease of maintenance.
I am having an issue in converting the following expressions
            <expression>{forest,wood}</expression>
            <expression>'residential'</expression>
which results in
    EXPRESSION "{forest,wood}"
    EXPRESSION "'residential'"
and the original working map file is
  EXPRESSION {forest,wood}
  EXPRESSION ‘residential'
The xml validates against the xsd/xsl, and the conversion line is
xsltproc mapfile.xsl layerset_9.xml > ../min-base/layerset_9.map
The documentation (7.0.4) states
List expressions (see rfc95) are a performant way to compare a string attribute to a list of multiple possible values.
Their behavior duplicates the existing regex or mapserver expressions, however they are significantly more performant.
To activate them enclose a comma separated list of values between {}, without adding quotes or extra spaces.
Any pointers to where I am going wrong would be helpful.
Thanks
Aimee
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170312/92c2694b/attachment.html>
