[mapserver-users] Default Values in Runtime Substitution Error
Lars Schylberg
lars.schylberg at blixtmail.se
Tue Mar 14 12:34:47 PDT 2017
This should help:
http://mapserver.org/cgi/runsub.html#default-values-if-not-provided-in-the-url
/Lars S.
Den 2017-03-14 kl. 19:38, skrev Stefanos Anastasiou:
> Hi all.
> I'm trying to perform a runtime substitution in MapServer. My
> mapfile snippet is the following:
> VALIDATION
> "val_1" "^[0-9]+(\.[0-9]+)?$"
> "val_2" "^[0-9]+(\.[0-9]+)?$"
> "val_3" "^[0-9]+(\.[0-9]+)?$"
> "val_4" "^[0-9]+(\.[0-9]+)?$"
> END
> METADATA
> #various WMS parameters
> END
> TYPE line
> STATUS on
> CONNECTIONTYPE POSTGIS
> CONNECTION 'host=localhost port=5432 user=stefanos
> password=myPassword dbname=dbName'
> DATA "geom FROM (SELECT * FROM stored_function(%val_1%, %val_2%,
> %val_3%, %val_4%)) AS foo USING UNIQUE seq USING srid=2100"
> If I pass the parameters in my url, everything works well. The problem
> occurs when I don't pass any parameter. The MS_ERROFILE gives me the
> following error:
> Error (ERROR: syntax error at or near "%"
> LINE 1: ...'hex') as geom,"seq" from (SELECT * FROM _a_route(%val_1%,
> %val_2%...
> It's necessary not to pass default values like "default_val_1"
> "some_value" because of a weird setup of my stored function.
> Is there any way to fix this ?
> Thanks a lot...!!
> -Stefanos
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170314/e37615b5/attachment.html>
