[mapserver-users] Allow request in http and https
Steve Toutant
Steve.Toutant at inspq.qc.ca
Wed May 3 06:49:15 PDT 2017
Setting the default resolution at the map level in the mapfile would do
that?
http://mapserver.org/mapfile/map.html
RESOLUTION default is 72
De : Andrea Peri <aperi2007 at gmail.com>
A : "Kralidis, Tom (EC)" <tom.kralidis at canada.ca>
Cc : "Mapserver-Users \(mapserver-users at lists.osgeo.org\)"
<mapserver-users at lists.osgeo.org>
Date : 2017-05-03 01:47
Objet : Re: [mapserver-users] Allow request in http and https
Envoyé par : "mapserver-users"
<mapserver-users-bounces at lists.osgeo.org>
Hi Tom,
thx for hint.
I forgot totally tht the onlineresource mapffile parameter was otionally.
Removeing it , the system work as I need.
Infact the mapserver retrieve the url from the request url.
Before of all I notice that the mapserver use before the
"wms_service_onlineresource"
and if it is not available use the
"wms_onlineresource".
So I remove both and effectivelly the mapserver produce automatically the
url.
It is what I need to support our two kind of portals protocols (http and
https)
I notice only one residual problem.
In the wms_onlineresource parameter we put some extra parameter:
like (for example) the
map_resolution parameter
http://myserver.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsambamm&map_resolution=91&
we need it to increase the resolution of all the getmap request of the
qgis clients.
removing the wms_onlineresource mean that the getmap requests are all
resolved using the resolution 74dpi and this mean a lower quality
level.
The perfect solution so will be to hvae a postfix parameter to define
an append string for the urls.
Something like this:
"wms_onlineresource_postfix" "&map_resolution=91&"
to have a result URL with added the string defined in the
wms_onlineresource.
A.
2017-05-03 1:31 GMT+02:00 Kralidis, Tom (EC) <tom.kralidis at canada.ca>:
> What happens when you do _not_ set ows_onlineresource? I think
> will automagically determine the URL?
>> -----Original Message-----
>> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
On
>> Behalf Of Andrea Peri
>> Sent: 02 May 2017 18:26
>> To: Richard Greenwood
>> Cc: Mapserver-Users (mapserver-users at lists.osgeo.org)
>> Subject: Re: [mapserver-users] Allow request in http and https
>> mmm...
>> Perhaps for the resource-online url could be better a setting like:
>> "ows_resourceonline" "auto"
>> Where "auto" mean that the mapserver retrieve the url (and the protocol
used)
>> from the request url of the getcapability request.
>> This was the better solution.
>> Infact if the client request on an https protocol it will return a
capability files
>> with all the request in https.
>> And if the client request using an http protocol it will return a
capability with
>> http protocol.
>> 2017-05-02 21:14 GMT+02:00 Richard Greenwood
>> <richard.greenwood at gmail.com>:
>> > If you really have to have two different wms_onlineresource and if
>> > Steve's suggestion to leave out the protocol didn't work, then you
>> > could create two ows URLs and use the map file's INCLUDE directive to
>> > refer to the same map file just using different wms_onlineresource in
the
>> two.
>> > On Tue, May 2, 2017 at 11:14 AM, Andrea Peri <aperi2007 at gmail.com>
>> wrote:
>> >> Hi Jukka,
>> >> my trouble come from a webapplication using geotools lbrary.
>> >> Seem that the geotools when try to connect to a WFS server (and I
>> >> guess also to the WMS) start with a getcapabilities request and
remap
>> >> the getmap using it.
>> >> We have many portal using http.
>> >> Now there is a new portal using https, and it should access to the
>> >> same wms services.
>> >> So I have a portal using https that is using also http protocol.
>> >> As I understand the web browser refuse to allow an http request when
>> >> the father page is coming from an https request blocking them.
>> >> A.
>> >> 2017-05-02 16:50 GMT+02:00 Rahkonen Jukka (MML)
>> >> <jukka.rahkonen at maanmittauslaitos.fi>:
>> >> > Hi,
>> >> > Actually your Mapserver will respond both to http and https
>> >> > requests if your network let them both come through.
OnlineResourse
>> >> > has no effect at all for Mapserver, you can set it to
>> >> > http://foo@bar if you wish. But WMS clients may have difficulties
>> >> > if they really interpret the GetMap URL and use it for further
>> >> > operations. QGIS and OpenJUMP have an override for using the same
>> >> > base URL that was used for doing GetCapabililies and that might
>> >> > suit for your case. OpenLayers, Leaflet etc. don't even parse
>> GetCapabilities and http://foo@bar is totally OK for them.
>> >> > -Jukka-
>> >> > -----Alkuperäinen viesti-----
>> >> > Lähettäjä: mapserver-users
>> >> > [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Andrea
>> >> > Peri
>> >> > Lähetetty: 2. toukokuuta 2017 15:37
>> >> > Vastaanottaja: mapserver-users at lists.osgeo.org
>> >> > Aihe: [mapserver-users] Allow request in http and https
>> >> > Hi,
>> >> > I need to set a mapserver wms to responde both on an http url and
>> >> > on an https url.
>> >> > I try seting two time the
>> >> > wms_onlineresource value:
>> >> > "wms_onlineresource" "http://my-server/...."
>> >> > "wms_onlineresource" "https://my-server/...."
>> >> > But the getcapabilites response oonly the second value.
>> >> > Is possible to set two url in the wms_onlineresource ?
>> >> > Many thx.
>> >> > Andrea Peri
>> >> > qwerty àèìòù
>> >> > _______________________________________________
>> >> > mapserver-users mailing list
>> >> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >> Andrea Peri
>> >> qwerty àèìòù
>> > Richard W. Greenwood, PLS
>> > www.greenwoodmap.com
>> Andrea Peri
>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170503/3689cc0e/attachment-0001.html>
